Build Thread Of A Clean And Sparkly 5K
Do it! if all else fails, run the c**t on gas.
  • Replies 74
  • Views 37.7k
  • altezzaclub
    altezzaclub
    maths fail??   20% is 1/5th, and a 1/5th of 44 is about 9kw, so you're limited to 53kw.... Not that anyone is going to check, and certainly not that an old 5K would make anywhere near 61kw today!
also not planning on keeping this 5k.
LOL yea true SLO-030. at $60 for a regrind, its really tempting to put a cam in her...
Let me know how much you want for her, mate
I need a 5k for my ksev so do a low comp setup and sell it to me cheap lol
Also were do we get $60 regrinds? I want this alalalalaah
Crowcams, I believe.
its look like its gonna cost me around $700 ish for parts and labour so far. ill be asking excess of a grand if i cam and double valve spring her. witch sounds VERY reasonable
also FYI a 5k intake manfold has bigger ports than stock 3/4k!
ill regrind the cam when ryan sends me his cams over :P
Stated my interest on page 1 for this bad boy. Something tells me my 426,xxxkm 4k wont last till this time next year. I'll even rep an EVSKI rollasports sticker on the window :P
edit: EVSKI
Edited by Crowie55
its EVSKI Rollasports, GOSH get it right :P :lolcry:
crowie has offically got dibs on this 5k.
updates - ill take the head to my guy on monday. he'll check all the valve guides, crack/pressure test the head. then measure the CC in the head and block. shave the head accordingly.
no solid conversion for this baby! hydros FTW
mmmm quiet, clean, not leaking... just the way I like them.
oh... errr... and yes plans for the engine sound good too Evan :P
Sounds like Crowie needs a tissue or forty...
Get the lumpy cam and put it in your car Evan!
Only half a mm bigger.
Have you even compared 3/4k std port and 5K ports?
Yes we have around 10 manifolds i will be happy to measure them somtime this week and post the results up.
Are they off of both deep and shallow dish 5K's there is a difference between the two, both in head and manifold.
