Heavy Accelerator (4Age)
cozza_mane
Ok took the rolla out for a spin since getting myself a daily.
Haven't done much at all except a bit of sanding.
Enough chat, I was just wondering as to what I can do to get it soft like my 4wd, cable loops around so anyone know what other cable would do, otherwise il just measure the distance and see what I can put on.
The car is a ke55
Link to comment
Share on other sites
i actually shortened my ke70 cable.
just hacked up the outer plastic casing, cut out a bit, "joined" it back together using a little peice of metal tube to join the plastic casing back together.
seems to work well.
mine does need an oil though thats for sure.
Link to comment
Ok so il take it out, cut of some oil it and put here back in. I don't want to try and take it off the throttle so I've taken cable off at the accelerator pedal.
Do you reckon solder is strong enough, as I was thinking of turning a flange at work with a through hole and counterbore one end with wire hanging through and putting a clump of solder in the counterbore and heating them together.
Link to comment
Over time cables just stretch and kink up internally
when installed with bends, even with oiling...
Buy a new cable, std or teflon one.
Shorten and carefully deburr end, fit cap.
Buy end stop from bike shop.
Fit and drive away?
Edited by styler
Link to comment
