JRADSTRX Posted June 1, 2011 Report Posted June 1, 2011 does anyone know whether ke70 or 86 swaybars fit a rt142 corona with solid rear end? Quote
silverra23 Posted June 8, 2011 Report Posted June 8, 2011 why not compare part numbers on the whiteline website and see what you come up with? Quote
altezzaclub Posted June 8, 2011 Report Posted June 8, 2011 What sort of rear end?? Supra IRS? Celica 5link? The RT142 Corona is quite similar to the MA61 Supra, just with a shorter nose - or more accurately the RA65 Celica given that it is a rear wheel drive platform built around an inline 4 cylinder Toyota "R" engine, has a "W5x" gearbox and has an "F" series IRS rear end. Quote
Des Posted June 9, 2011 Report Posted June 9, 2011 Solid = Same setup as a ke70, 4 trailing arms an a panard rod Quote
Jono.C Posted June 9, 2011 Report Posted June 9, 2011 Live axle is the correct term. Why would you want a ke70/ ae86 swaybar in it? surely they'd be smaller? you'd be better off using an aftermarket one suited to the corona. Although, you can use an ra60 swaybar as an upgrade in a ke70, and Xa6X's and XT14X Share the same chassis so i'd say maybe. But i don't see the point Quote
ke70dave Posted June 9, 2011 Report Posted June 9, 2011 i reckon he must be trying to adapt an aftermarket ae86/ke70 item to his corona. Quote
