July 24, 201115 yr comment_541856 was playing with it just before and rpm goes to 32 000 it goes to 2 digit numbers on the bar graph so enough revs for anything Wow 32000rpm. Only things I know that spin that hard are the little nitro RC engines. I wanna see it running, and some numbers from the dyno. Stu. Report
July 24, 201115 yr comment_541867 I wanna see it running, and some numbers from the dyno. +1 !!! :yes: Report
July 24, 201115 yr comment_541877 might not be running on E85 for its first few events cause i don't have any and when we need it next i get it cheaper instead of buying just for this but we have plenty of avgas :) don't need that much power and i want it to last so ill give it as much timing as it will take then pull a few degrees out and richen it up a bit but when i get my E85 in it ill see what it can do then :) gotta remember the engine is 100% stock inside only has a new HG cause it was blown from boiling so often haha i don't stop if water boils if i lose oil press i think about it a bit haha Report
July 25, 201115 yr Author comment_542286 First race date set 28 September should be a big day with 30+ people and hoping i can win, few rally cars coming but can only run radials and with my no rules i rekon i can back myself to win against similar car with rally rules so see how i go after the 28th got some work to do :) (28 of august not september) Edited July 30, 201115 yr by mitch-12 Report
July 30, 201115 yr Author comment_543342 Got some done today only took two pics i have fuel pressure now woohoo and incar loom is finished also started on engine loom Returnless fuel system ecu to firewall loom i have 3 more weekends before its time to race so should be going in that time easy Report
July 31, 201115 yr comment_543477 i have 3 more weekends before its time to race so should be going in that time easy Famous last words lol :lolcry: Looks good as mate and I'm sure will be one sweet racer when its done :happy: See ya Jimi Report
July 31, 201115 yr Author comment_543511 haha i have faith I'm uploading pics now the ecu talks to the dizzy so i know it will run and has spark woohoo Report
July 31, 201115 yr Author comment_543515 Also I'm redoing my front end i have better ideas since i built it last time should be good Report
July 31, 201115 yr Author comment_543521 i only used it on the plate for the bosch bov on the supercharger pipe everywhere else i would rather have gaskets or 515/518 if it is a flat surface Report
August 1, 201115 yr comment_543719 Hahhaha yep :wink: Looks good as bro keep it up :happy: See ya Jimi Report
August 1, 201115 yr comment_543769 Do you have a tension pulley between the Sc and the crank pulley? Report
August 1, 201115 yr Author comment_543787 Do you have a tension pulley between the Sc and the crank pulley? no tension pulley still need to make a top bracket for the sc and a plate on the pulley to keep the belt aligned Also got the engine loom finished just needs injector plugs and i have spark woohoo :D and everything else works perfectly Report
August 2, 201115 yr Author comment_543986 it goes :D:D:D:D:D:D:D:D <iframe width="425" height="349" src="http://www.youtube.com/embed/mZ02XJtBeJc?hl=en&fs=1"'>http://www.youtube.com/embed/mZ02XJtBeJc?hl=en&fs=1" frameborder="0" allowfullscreen></iframe> this might fix it http://www.youtube.com/watch?v=mZ02XJtBeJc&feature=player_embedded this might work http://www.youtube.com/watch?v=mZ02XJtBeJc&feature=player_embedded http://www.youtube.com/embed/mZ02XJtBeJc?hl=en&fs=1 Edited August 2, 201115 yr by mitch-12 Report
