Ls7 Ke70 Racecar Build!!
was playing with it just before and rpm goes to 32 000 it goes to 2 digit numbers on the bar graph so enough revs for anything
Wow 32000rpm. Only things I know that spin that hard are the little nitro RC engines. I wanna see it running, and some numbers from the dyno.
Stu.
  • Replies 861
  • Views 947.7k
  • When the fuck are you cunts going to shut the fuck up and leave the kid alone, he is 17, most 17 year olds say stupid shit including you Evan which is why there used to be a page dedicated to you from
  • You gotta be kidding me Mitch....   I'd rather be out machining flywheels and destroying tyres than making excuses ;)
  • Evan why don't you shut the ʞ©$ɟ up and lay off people, you aren't much fucking better.
+1 !!! :yes:
might not be running on E85 for its first few events cause i don't have any and when we need it next i get it cheaper instead of buying just for this but we have plenty of avgas :) don't need that much power and i want it to last so ill give it as much timing as it will take then pull a few degrees out and richen it up a bit but when i get my E85 in it ill see what it can do then :) gotta remember the engine is 100% stock inside only has a new HG cause it was blown from boiling so often haha i don't stop if water boils if i lose oil press i think about it a bit haha
First race date set 28 September should be a big day with 30+ people and hoping i can win, few rally cars coming but can only run radials and with my no rules i rekon i can back myself to win against similar car with rally rules so see how i go after the 28th got some work to do :) (28 of august not september)
Edited by mitch-12
Got some done today only took two pics i have fuel pressure now woohoo and incar loom is finished also started on engine loom
Returnless fuel system
ecu to firewall loom
i have 3 more weekends before its time to race so should be going in that time easy
Famous last words lol :lolcry:
Looks good as mate and I'm sure will be one sweet racer when its done :happy:
See ya
Jimi
haha i have faith I'm uploading pics now the ecu talks to the dizzy so i know it will run and has spark woohoo
Also I'm redoing my front end i have better ideas since i built it last time should be good
threebond is the best shit ever!
i only used it on the plate for the bosch bov on the supercharger pipe everywhere else i would rather have gaskets or 515/518 if it is a flat surface
Hahhaha yep :wink: Looks good as bro keep it up :happy:
See ya
Jimi
Do you have a tension pulley between the Sc and the crank pulley?
no tension pulley still need to make a top bracket for the sc and a plate on the pulley to keep the belt aligned
Also got the engine loom finished just needs injector plugs and i have spark woohoo :D and everything else works perfectly
