Ls7 Ke70 Racecar Build!!
...and you're making some braces to keep everything where it is right now!
I wouldn't hit the dirt without a strut brace across the top, those strut pillars move a lot especially when you land
  • Replies 861
  • Views 947.7k
  • When the fuck are you cunts going to shut the fuck up and leave the kid alone, he is 17, most 17 year olds say stupid shit including you Evan which is why there used to be a page dedicated to you from
  • You gotta be kidding me Mitch....   I'd rather be out machining flywheels and destroying tyres than making excuses ;)
  • Evan why don't you shut the ʞ©$ɟ up and lay off people, you aren't much fucking better.
I'm doing whatever is cheap ill work it out later i need to plumb bob it from suspension mounting points to work it out properly.. also what are the 3 vacuum/boost ports on the sc for? and ive given up on front roll centre i can do it but i can't be bothered, to make it work properly the rack needs to move up or down depending on where i adjust bottom arms to for roll centre for the bump steer to be correct and i can't be bothered lol.. thats about it from me tommorow i am ordering 10L fuel cell getting my bulkhead plug for the engine loom and maybe thinking of putting my wolf 3d in it and using motec for my F100... not sure so ill order plug and pins for motec it has same plug as wolf and ill be sweet
Edited by mitch-12
i drove it after dad and he broke the stick in his last session so i was stuck in 3rd haha
The old Corolla goes round there in 1.45 stuck in 3rd too :dance:
haha you have a more usable rev range
My sc/12 had those too. Was connected to a solenoid on mine so I removed it all and used the rubber vacuum block offs. I presumed it was for sensing over boost and/or low throttle and would cut the power to the clutch and let it free spin a bit. But I may be wrong.
So it looks like those arp part numbers were right then.
Stu.
dad got them when he was in us he was at the factory for 3 days i just told him what size the bolt was and thats what he got i think they are 4age long studs
Nice!! Yeah man two half sets of long ones.
Stu.
well actually he made them while he was there pretty cool some people say that the 3 ports are to equalize pressure of the bearings or something have to run boost into them.. ill do some more research also I'm building the sc bracket this week need to get as many ideas as possible to make it best as possible
More than likely to equalise pressure to stop oil being drawn into the intake under vacuum.
your right i pm'd neil and thats what they are for run them into one then to intake mani
Winning :P
Pretty sure there is 1 port in each end = 2 and 1 in the outlet side. So join all 3 together and that will be it. Pressure in the outlet of the blower will regulate pressure in the ends. (read: Been quite a while since I had my SC12)
Wolf doesnt have enough inputs and outputs motec it is
also fixed this uglyness gallery_10453_425_1365457.jpg i flared it with multis to fit some 225 15s ages ago gallery_10453_425_959414.jpg first time ive ever bogged gallery_10453_425_1281245.jpg came out good enough :) gallery_10453_425_1180335.jpg and this is what it used to look like gallery_10453_425_53068.jpg
gallery_10453_425_1294448.jpg gallery_10453_425_456745.jpg gallery_10453_425_793607.jpg gallery_10453_425_490592.jpg gallery_10453_425_775715.jpg
is that a humpy in the shed in the background?
