Ls7 Ke70 Racecar Build!!
so is the sc14 or the sc12 better i went the 14 so it will spin slower and create less temp theoreticaly well thats in my head haha
Sc14 will be better as it delivers more air per revolution.
So, to produce the same amount of "boost" (flow of air) it will have to rotate fewer times.
  • Replies 861
  • Views 946.5k
  • When the fuck are you cunts going to shut the fuck up and leave the kid alone, he is 17, most 17 year olds say stupid shit including you Evan which is why there used to be a page dedicated to you from
  • You gotta be kidding me Mitch....   I'd rather be out machining flywheels and destroying tyres than making excuses ;)
  • Evan why don't you shut the ʞ©$ɟ up and lay off people, you aren't much fucking better.
yeah thats my idea behing having it and also since it is spinning slower to produce same psi as sc12 it might run cooler
July eh, well that will give you a couple of months to practise for the bit Corolla showdown when I get back :)
Thats it man. "Boost" is the pressure of the air built up that the engine can't "swallow". So if you were to spin an SC12 to supply 20psi. Then you upgraded to an SC14 you'd have to spin it slower to keep the boost at the same figure.
yeah ill try and learn about what temps they fail at and have a air temp sensor before the intercooler so i know how hot the charger is :)
Rob its on and i got slicks now hehe
anyone know what temp they melt at
you don't have to have a cage to run at winton. It doesnt matter how somethng looks its if its safe mechanically and with appropriate seat, seat belt, extinguisher etc. I've scruitneered that car a couple of times for events already and it aint pretty but it gets a tick mechanically.
I've been out of the round and round stuff for a few years, but it used to be that you couldn't run slicks without a cage. Which, oddly enough, I agree with.
That was CAMS, I'm assuming this is AASA being Winton?
Yes its AASA, i havent scrutineered it for circuit racing so you could be right on that regulation.
i think its fround upon but for sprint series and tampered day you can run without a cage i don't really know usually I'm in a v8 supercar it has a cage so yeah
it hasnt got much power so it wont be super fast
it will be quick with the charger man just get a half cage man ud be shocked how quick a car will roll just takes one little bit of oversteer u shit hit the brakes tires grab and throws the thing on its side.
has happened to alot of people man, tap the ripple strip and rolls cage will save ur life man
It's not the "no cage" bit that concerns me. Many sprint series run without manditory cages.
It's the slicks and no cage that you may have issues with.
That said, I can't find anything about it in the current CAMS manual. (yes, I know, AASA....)
Do the Supp Regs for the event have anything t say about it?
Edited by Redwarf
