202 Or A 179Hp
hi there how hard will it be to fit a 202 or a 179hp into a ke 30 corolla how hard will it be any help .
??? So many Other engines to put in .. Y the old straight 6. 202 ?
Wouldn't be too hard to make mounts but would probably need firewall cut if you want any kind of good weight distribution, they can make good power though, I have a mate that has a 202 in a LJ 2 door running about 300HP not sure if its at the wheels or fly but it sounds oh so good :)
pretty much what it sounds like and its very loud!
http://www.youtube.com/watch?v=pzG5b80KHvw&feature=related
202 n all Holden straight 6 r good specially with triple carbs .. :)
yeah um i don't think i will have to mod fiawalls but um i will have to run the radator side ways .
It would be like driving a elephant in a shopping trolley.
why will it be what do u reckon it will be shit in it.
It's a pretty heavy engine. It would be great going in a straight line but when it comes to handling... :no2:
all i have to do it un bolt my front panel the bit that ublots and bolt it forward more :)
and panel mounts, bonnet catches, bumper mounts. Lot of work to do when you could have it done twice as easy by cutting and boxing the firewall.
I'd go the 179hp they had a better crankshaft than the old 202
Its been before and a member from memory had a ke30 posted up and yes the radiator was mounted sideways. Its just boils down to what your going to use it for. Burnouts, drags but any circuit work it reconsider the choice strongly as the handling will just go out the window as mentioned by the other guys.
Good luck with the build mate :y:
If I were to go for an Old Straight-6, I'd go for the 250 Crossflow. :yes:
Josh :cool:
