Tim54321 Posted August 16, 2011 Report Share Posted August 16, 2011 hey guys when i brought my ke20 it had no carpet, so i got "moulded" ke20 carpet from ebay, my question is pretty simple, should i get underlay as well or would it be ok just with carpet?? (not sure where to post this sorry) Quote Link to comment Share on other sites More sharing options...
ae824ate Posted August 16, 2011 Report Share Posted August 16, 2011 Your choice. If you put insulation under it itll be quieter on the road. I ripped mine out to save weight :P Quote Link to comment Share on other sites More sharing options...
mattress Posted August 16, 2011 Report Share Posted August 16, 2011 Having just put extremely good quality thick underlay into a KE20 i would advise against it. For me it made the carpet and accessories harder to fit. Perhaps something a little thinner would be the go or not at all... Quote Link to comment Share on other sites More sharing options...
love ke70 Posted August 16, 2011 Report Share Posted August 16, 2011 mmm, probably wouldnt bother, the carpet will kill a good bit of the noise, and the underlay can make issues with the pedals etc... Quote Link to comment Share on other sites More sharing options...
philbey Posted August 16, 2011 Report Share Posted August 16, 2011 I disagree with the previous comments: underlay isn't so much about dampening noise, its there to add a pliable layer so the carpet doesn't thrash out. Without underlay you'll wear the carpet out in places much quicker as it works against the floorpan etc. I fitted molded carpet with underlay and it was not difficult Quote Link to comment Share on other sites More sharing options...
Timofee Posted August 16, 2011 Report Share Posted August 16, 2011 mmm, probably wouldnt bother, the carpet will kill a good bit of the noise, and the underlay can make issues with the pedals etc... had that issue when i was replacing the carpet for my vh commodore.. redid with epic expensive underlay sound deaden-er shit And it f@$ked me up hardcore.. had to cut patches out in the footwell near the clutch pedal because couldn't put my clutch on all the way enough for it to do the job properly.. though in the end it depends if you want to or not. Underlay would give more comfort n shit but isnt necessary as well your not going to be standing up in your car for 8 hours a day. And unless your making a pro showroom car. Probably wouldn't need it.. road noise you will get. but the carpet takes care of most of that :) Quote Link to comment Share on other sites More sharing options...
Tim54321 Posted August 16, 2011 Author Report Share Posted August 16, 2011 Thx for all the replys guys, i might just not bother with the underlay =) Quote Link to comment Share on other sites More sharing options...
philbey Posted August 17, 2011 Report Share Posted August 17, 2011 There's a difference between underlay (20 bucks per roll) and sound deadener like dynamat (300 bucks a roll. Quote Link to comment Share on other sites More sharing options...
ke70dave Posted August 17, 2011 Report Share Posted August 17, 2011 carpet straight onto the body would be horrible... not only from a wear and tear point of view, but it woudlnt be as soft under you feet, and you will be able to see more of the ridges. and the carpet will move around. for the extra 20bucks and bit of effort i would get it, your getting brand new carpet, you might as well do the job properly. and just don't put it up around your pedals, problem solved. the underlay will also act as an insulation, your exhaust will heat up the passenger side footwell, no one likes their feet cooked. Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted August 17, 2011 Report Share Posted August 17, 2011 ..and now you know its fiddly job to get it done well, so expect to spend a long time getting it right. I'm happy to use screws to hold it in place and keep its shape. Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted August 18, 2011 Report Share Posted August 18, 2011 (edited) Find a new estate where lots of houses are being built. Free under lay . I only laid it in the foot wells and a double layer in drivers one. If you go without just make sure you have mats. EDIT: I got it out if skips I didn't steal rolls of it :P Edited August 18, 2011 by blzbub666 Quote Link to comment Share on other sites More sharing options...
dbr11k Posted August 18, 2011 Report Share Posted August 18, 2011 what reed said ^^^ i used old underlay from the office .. feels really good under the feet. if you don't use underlay than as soon as you get a few rocks under the carpet it's gunna wear it out in no time. Quote Link to comment Share on other sites More sharing options...
Tim54321 Posted August 18, 2011 Author Report Share Posted August 18, 2011 lol hmmm maybe i might put some underlay in then =) Quote Link to comment Share on other sites More sharing options...
