JDM KE70 Posted November 22, 2011 Report Share Posted November 22, 2011 hey guys, My 1979 t-18 fitted with the stock 3tc with 155,000 kms on the clock. Serviced every 2 months or soo. :yes: Anyways the oil pressure has gone nuts when hot at random. :bash: I wanna top know if anyone has any idea about this problem.. Any help would be great before i pull my sump off and replace the pump. :dance: cheers Nathan. Quote Link to comment Share on other sites More sharing options...
Evan G Posted November 22, 2011 Report Share Posted November 22, 2011 Too much or too little pressure? Have you got a manual gauge on it? Quote Link to comment Share on other sites More sharing options...
styler Posted November 22, 2011 Report Share Posted November 22, 2011 The pump has an inbuilt bypass when pressure gets too high, can get jammed if pump is old. Quote Link to comment Share on other sites More sharing options...
7shades Posted November 23, 2011 Report Share Posted November 23, 2011 Car is a future Jedi Knight. The council won't like it, but you will have to take it upon yourself to train it and ensure it does not turn to the Dark Side. 1 Quote Link to comment Share on other sites More sharing options...
ke70dave Posted November 23, 2011 Report Share Posted November 23, 2011 is the guage shorting out? if a sensor/guage throws up odd readings, first step....look into sensor/failures. Quote Link to comment Share on other sites More sharing options...
JDM KE70 Posted November 23, 2011 Author Report Share Posted November 23, 2011 the pressure is high didnt think this would happen beening so old and all.. replaced 2 oil filters oil and oil pressure sensor already. its come good atm but not wanting it to happen again. Quote Link to comment Share on other sites More sharing options...
JDM KE70 Posted November 23, 2011 Author Report Share Posted November 23, 2011 is the oil pump valve getting stuck the normal fault. has this happened to you? Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted November 23, 2011 Report Share Posted November 23, 2011 If the gauge gets shorted out I believe it goes to max reading, so it could also be in the wiring anywhere from the gauge to the sender. Hopefully a new sender unit sorted it out. I can't see the pump delivering more than 60 or 70psi a the most, and that is when cold. Quote Link to comment Share on other sites More sharing options...
JDM KE70 Posted December 1, 2011 Author Report Share Posted December 1, 2011 Replacing the pump tonight. Fingers crossed!!! Quote Link to comment Share on other sites More sharing options...
