Urgent: Flywheel Bolts
Ive got what i think to be 4 flywheel bolts for my 4age (need 8), but I'm not quite sure. What other egnine use the same bolts as the 4age so i can get them. Or do any one have any they would like to sell to me. Need them asap for engine balence.
Thanks Jason
I wouldn't mix and match bolts from other models due to strength ratings...
Order new ones from Toyota...
would probably be quicker to order them new aswell
what would be cheaper and or faster?
Were do i order through toyota?
Are they a special type of bolt?
If not - Can you just go to your local "Nut and Bolt Place" and grab some Hi-Tensile Bolts.
Thats all i did on my 5K. Along with some some Spring washers and some Loctite.
Yah teddy ordered me some through toyota for $3 a peice :y:
Gotta be happy with that. I payed $9 each for a M18 bolt once :P never again.
holy shit. they wanna be prety good for that.
just gonna say, don't skimp on quality though cause a flywheel kinda needs to be pretty secure :y: have heard horror stories about them coming up through the trans tunnel. :P
ahaha yes, i have heard one of those stories too... something about a mini's flywheel coming off, and missing the passenger by a bee's dick :y:
http://www.exvitermini.com/pics/getrgo1.jpg
clutch failure on a Getrag R34 6spd = not cheap
Mind you it was making a bit more power than standard. (not GTR700 btw)
I have a suspicion that the whole "flywheel coming through the floor pan" thing is a bit of a myth unless your making LOADS of power. The only other way I recon it could happen was if you had a simultanious failure of the input shaft, clutch and flywheel bolts.
When you think about it if the flywheel bolts fail youve still got the clutch attached which will still hold onto the input shaft (which, in my case still rests in the end of the crank not the flywheel). Yes its still a fairly major failure but I don't see it flying through an alloy bellhousing with big enough hole to still have enough energy to slice through the firewall.
I have a nice pic somewhere of an RX3 from NZ...
Flywheel sized hole in the bellhousing and bonnet... Not to mention rest of the engine bay being destroyed...
