Now, I'm not sure how well i can explain this.. But i'll give it a go.
With the sleeve kit going on my T18 struts the ride height will sit pretty low, and this means the factory shocks are way too long and will bottom out..
I don't currently want to spend 300 + some on KYB's to try and fix this as it was something i'd planned to do later..
So, my idea was.. Measuring up the front shocks, putting them in the lathe, shortening them (the actual rod not the body) and then nurling the ends down and tapping the thread on..
Thus leaving them shorter to keep the springs captive and they wont bottom out..
Any idea's on if this possible? I'm unsure whether the tube itself is hollow or not.. But in theory it might work
As i said might not be easy to understand what i'm getting at but..
Edited by Jono.C
Not a problem at all just done it with a tap&die set but if you are geared up on the lathe then you could use that .We started with standard KE11 struts with OTTO-MOTTO coil over kit and Pedders gas comfort ride shockers ,KE30 front discs all works fine.
Cheers:- Stuart.
Awesome, Thanks.
How did you measure your shocks out? Because i'm going to have to shorten them in such a way that i can still adjust my coilover kit, and not have them top out
Did consider this method just remember those shafts are hardened so you might have to cut the thread with a bit on
a lathe rather than use a die and the top section is usually profiled ie has a double d step which locates on the upper hat
to stop it turning when tightened up or removing the nut. If you have aftermarket hats then you could keep it round
and use a rattlegun but I rememeber there was some problem with adjustable dampers and using a rattle gun so keep
that in mind.
that in mind.
Some adjustable shocks have the adjusted in the top of the shock ram (ie Koni EXTERNALLY adjustable). Using a rattle gun could damage it.
I've herd of it being done before the main thing i would worry about first is if you will even have enough travel from the top of the strut tube to the top hat this is the problem i had with my ke20 struts the actual strut body is too long to run a low ride height i had an inch of travel between the the gland nut and and the bump stop.so any shortening the shaft could be pretty much useless.
