June 2, 201214 yr comment_607561 Greetings all...Looking in my Haynes manual, I only see one measurement for the strut no matter if a 1.1, a 1.2 or a 1.6 Corolla !967-1974. Shopping at RockAutoParts.com...they show a strut insert for a 1973 1.2 but for nothing earlier. Would this work in my KE10 strut tower. I think mine are blown cuz it rides like a rock now. I seem to live in a Elder Corolla free zone so I have to work with what I've got...no going out and finding KE20's or 30's parts laying around. Report
June 3, 201214 yr comment_607592 A bloke i know down here in Tassie put ke20 strut inserts in his ke10 struts. From memory he said they were a longer stroke. But, You guys got TE not Ke.. And i'm thinking they might be different struts.. Could be wrong but.. Also if you're talking about putting ke20 struts in your ke10? Stu (kick5k) has ke20 struts in his ke10 and reckons there's some positive camber going on Report
June 3, 201214 yr Author comment_607597 mines a KE10L K-C and here's the strut if this helps... Report
June 3, 201214 yr comment_607675 check Felixs tips on using Ke2/3 inserts: http://www.rollaclub.com/board/topic/7224-ke11-suspension/ Say clear of Te inserts as they will be too thick for the ke1 strut tube Report
June 3, 201214 yr comment_607699 I have heard mazda rx5 inserts will fit with 20mm spacer. its approx 25mm shorter at extended length so might suit a lowered spring or ke20 spring with ke20 top hat? Anyone confirm this? Report
June 3, 201214 yr comment_607723 Not sure. I doubt it to be honest.. Ke20 spring is about half a coil longer than ke10.. Plus it's about double the thickness so it wont compress anywhere near enough.. It might if you can get it to all compress Report
June 4, 201214 yr Author comment_607793 here's what my handy dandy much worn Haynes says...usually if there is a difference it will say so, but it's been known to be wrong Report
June 4, 201214 yr Author comment_607794 sounds like they will work, I may need a spacer...ordering them tonite...thanks a heap guys Report
June 7, 201214 yr Author comment_608532 Well from here the answer is no....I ordered the '73 strut inserts...the body is shorter and doesn't fit to the bottom of the tube, the length wouldn't matter so much, a large size old socket or something could drop in the tube first to take up the space but it stops 2 inches from being inside the tube far enough to get the top screwed on. The KE10 strut gets a tad bit narrower at the bottom. The top of the rod is shorter where the threads are and would not reach through the top cap to get the nut started. I had to put the worn out one back in, now...what to do with struts i can't use.....gotta call to see what the return will take....and keep trying to find something that will work. Edited June 7, 201214 yr by CorollaNut69 Report
June 8, 201214 yr comment_608568 There's a write up from "Felix" on putting later model shocks into early struts. But it's essentially this http://www.rollaclub...ts_on_your_KE1x And here in more detail http://www.rollaclub.com/board/topic/7224-ke11-suspension/ Edited June 8, 201214 yr by Jono.C Report
June 8, 201214 yr comment_608591 I've got some NOS Tokico inserts at home. I'll measure them up and post here. Report
June 9, 201214 yr comment_608804 Tokico S1002, but there is also a KYB part number on the box KC2005. Diameter of these inserts: 38mm Body length 431mm Stroke 190mm Report
July 3, 201214 yr Author comment_613550 Tokico S1002, but there is also a KYB part number on the box KC2005. Diameter of these inserts: 38mm Body length 431mm Stroke 190mm Thanks...so far I cannot find them for sale anywhere Report
