WillAnton Posted July 31, 2012 Report Share Posted July 31, 2012 Hello ladies and gents, I've just bought some 2nd hand ssr mesh wheels to go onto my ke38. The rear rims are spotless but the fronts are covered in what a can only describe as alloy grime...or lightly coloured rust. Not reeeally sure. I was wondering if I could get some tips on what to use to get them looking schmick. Pic to come later on today. Cheers Quote Link to comment Share on other sites More sharing options...
flyinwall Posted August 1, 2012 Report Share Posted August 1, 2012 autosol, a rag and some elbow grease Quote Link to comment Share on other sites More sharing options...
WillAnton Posted August 1, 2012 Author Report Share Posted August 1, 2012 autosol. right Cheers for that. Quote Link to comment Share on other sites More sharing options...
ke70dave Posted August 1, 2012 Report Share Posted August 1, 2012 depends how bad it is really. and how dodgy you are. i had a pair of SSR wheels that had major alloy corrosion. jacked up the rear of the car on stands, chucked a wedge under one side wheel so it coudlnt spin (open diff), thew a wheel on the other side. started engine, threw it in gear (started at 1st, ended up in 3rd i think). be VERY CAREFUL doing this.... wet and dry sandpaper on the alloy lip, start at 400grit, work your way up to 2000grit. then stop the wheel and get in there with an orbital polisher and some of that auto sol stuff. came up like a mirror! i got some weird looks from passes by, like theyd never seen a DIY lathe before Quote Link to comment Share on other sites More sharing options...
01sik Posted August 9, 2012 Report Share Posted August 9, 2012 Haha Dave, I wish Rolla club had a like button I was smiling cos I've done this and got the exact same looks hahahaha Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted August 9, 2012 Report Share Posted August 9, 2012 (edited) I wish Rolla club had a like button On the right there are two arrows, green for like, red for dislike. Unless you are on a phone. Edited August 9, 2012 by B.L.Z.BUB Quote Link to comment Share on other sites More sharing options...
19914afc Posted August 9, 2012 Report Share Posted August 9, 2012 I have also been told this method but my wheels weren't that bad just not mirror finish. Quote Link to comment Share on other sites More sharing options...
Chillin Posted August 9, 2012 Report Share Posted August 9, 2012 I have also been told this method but my wheels weren't that bad just not mirror finish. It will! if you work your blemishes out and work hard enough with the 1800/2000 grit to smooth, use a cut and polish cutting compound and rag, more pressure the better and it will come the goods, finish off with a round of the autosol and it will be smick! The 'one wheel up' method works really well, 5th gear at idle, just make sure you secure the car before attempting! Good luck and mind your fingers Quote Link to comment Share on other sites More sharing options...
