just brought my first ke11 and noticed how bad it tracks with the grooves in the road, is there anything to help this or is it just something you have to get used to???
at the moment its running 13x175mm meshies but i was hoping by throwinging the 12in stockies back on and doing the idler arm bush as well as the rear shackle bushes it would help cut it down a bit
any ideas???
cheers
i fond any bigger tyres than the stock 12" makes them track with road
lol try driving my wagon with 15" wow always counter steering it lol
The problem is theres no castor adjustment with the ke10's.... datto 1200's do it aswell as you can't adjust the castor until you thread the castor rod more and add an extra nut and wind some castor into it... as soon as you add abit more castor they stop tracking so bad. As everybody else has said tyres aswell shaun. :) Have fun...... remember to do your wheelnuts up lol
Yeah no worries , I'm getting 4 New tyres on the standard 12in rims on Monday as well as a wheel alignment and I'm going to replace the idler arm bush as well as the rear shackle bushes, so hopefully that helps abit with the handling side of things
If there is a range for toe measurements in the specs, have them set it towards the toe-in end of the range rather than the tow-out end. Toe-out makes it track more.
The Altezza specs are total toe +0.8mm (min -0.7 to max +2.3mm) So anywhere from toe-out 0.7 to toe-in 2.3 is considered fine. However toe-out crucifies the tyre's inner treads on those cars, so we always aim for 2 to 2.3mm toe-in.
Per Toyota
Tire inflation 18psi (!)
Toe in unloaded 2 - 6 mm (0.08 - 0.24'')
Camber unloaded 10 30' - 2030' (see below)
Caster unloaded -15' to 45'
kingpin inclination unloaded 60 - 70
Turning angle: inner 37 - 380
outer 32 - 330
Interestingly, in the supplement it notes: To prevent abnormal tire wear, the wheel alignment is changed in camber as follows by modifying the shape of the steering knuckle arm.
Camber loaded 30'
Camber unloaded 30' - 1030'
Production effective
KE10-290392
KE15-103923
KE16-169001
stationwagon
KE16-170000
delivery van
Anyone that is interested, the 30' in 1030' is 30 minutes, so it is 1.5 degrees.
Does it track all the time or only on certain roads?
