4Age Intermittent Starting Issues.
would insufficient grounding cause starting issues every single time I try to start it?
I'd expect that, but adding an earth is dead easy anyway.
  • Replies 34
  • Views 96.8k
  • 7 years later...
Hello everyone, first time posting on the forum.
I came across this thread, I have an Ae82 that has suddenly developed the exact same intermittent starting problem. Ignition timing varies as if the ecu forgets where TDC is on starting. Takes a few attempts to start. Either way too advanced or retarded. And sometimes starts first time with timing correct.
Tried swapping the ecu, coil and ignitor aswell as the distributor. Same issue.
Has the member that started the thread ever found the problem?
