October 17, 201214 yr comment_632280 Just planning to replace a leaky and clanking diff in my Ke35... What should I put? I'm hearing of hilux diff to be so good... what is the diff code? where can i find the markings? Thanks! Report
October 17, 201214 yr comment_632288 The diffs arent marked the body is on the build plate, if your lucky. A car that has a borgy has no stamp on the plate usually. Anyhow, look for the Hilux diff with the narrowest track and make that fit so its not too wide for your chassis. RN25 from memory. Edited October 17, 201214 yr by LittleRedSpirit Report
October 21, 201214 yr Author comment_632901 Thanks guys for the info... will this one fit? I look at frosty's link and see the code G142 and i believed this one have as indicated on the plate. The seller says it came from 1980 hilux 4WD and he is selling both diff front and rear. see pic bleow.. hope this one will do. Report
October 21, 201214 yr comment_632902 does he have the bellhousing/gearbox still? best way to see if it fits is by measuring across the leaf spring pin eyes and compairing it to the stock corolla diff Report
October 21, 201214 yr comment_632906 Hilux diff is heaps of work though... what motor is it behind? Report
October 21, 201214 yr comment_632907 My hilux diff was pretty easy to swap mounts over and if its going in a ke35 even easier. Report
October 23, 201213 yr comment_633125 just remember that the 4wd hilux is a 6 stud not the 5 stud falcon/camry/subaru pattern Report
