I am currently in the process of doing a ke55 project and looking at putting a 4age engine and box in, what would work better as in gearsticks lining up with the hole in the tunnel a fwd or rwd 4age?
FWD 4AGE and RWD 4AGE are the same engine. You want to use a T50 gearbox, the gearstick will line up with the hole in the trans tunnel regardless of whether your KE55 was auto or manual. Unless of course you've never heard of tin snips/grinders/dremels, then the gearstick magically may no longer line up...
Thanks guys i looked at a few boxes and one of them looked pretty long thats why i was abit worried about it, any other handy hints that might make my job easier would be much appreciated
If you use a ta22 t50 the gear stick will be in the same spot as factory .
If you use a later t50 the gear stick will come out about 17-20mm further back.
The only problem with the ta22 box is there is a bit moding to get a 4a bellhousing on to it.(other wise it will piss oil every where)
On the positive side the ta22 box will use the ke55 drive shaft.
rob
So pretty much the only thing i need in the driveline is a tailshaft, with your kit and the engine & box?
You'll need a hydraulic clutch pedal setup too.
Jordan do you do these for the earlier stuff or is it just the ksev? Might be worth looking into.
