April 20, 201313 yr comment_653870 Anyone have a manual for a 'k' motor they could tell me the points gap? I can't seem to find it on the net.. and unsure if its the same as a 3k or 4k.. Report
April 21, 201313 yr comment_653894 3K is 16 - 20 thou (0.4 - 0.5mm) Dwell 50 - 54 degrees Ign timing: 3K 8 degrees, 3K-C 5 degrees 3K-B 10 degrees 3K 600rpm, 3K-B 650rpm, 3K-C 750rpm 3K automatic 700rpm I don't have anything for one of those modern 4K's......... Report
April 21, 201313 yr comment_653896 Those numbers are pretty much the same as 4Ks, off the top of my head 4K is 8 degrees and points are 0.45. Edited April 21, 201313 yr by B.L.Z.BUB Report
April 21, 201313 yr comment_653904 the 1100 K-C motor is 0.4-0.5mm point gap...0.8mm plug gap.....5* ATDC @650 rpm....intake valve 0.08mm, exhaust valve 0.18mm...from the 1968 owners manual. Report
April 21, 201313 yr comment_653964 If you have a dwell meter it is more accurate than using feeler gauges. Once the points have a pit on one side and a lump on the other then feeler gauges measure it wrong every time. Even new it is easy to not get that gap perfect. 5deg is nothing! Do they respond well to more advance? 8-10deg on 95 octane?? Report
April 30, 201313 yr comment_654818 Yeah my 3K runs way better with more advance...I think it helps with the crappy ethanol gas we get now and I usually run the cheaper 87 octane...but he had asked for a K manual and that's the factory settings. Back then you got nice leaded gasoline...actually ran a bit quieter..and you could tell if the engine was running well from the chalky white tail pipe...if it was black in there like they all are now , something was wrong. My original 1100 K ran best at about 8deg or so....set it all up to factory and then just twist the dizzy till it pepped up a bit.....and it was OK with me taking it to 6600 rpms on a regular basis for about 300,000 miles after it's first freshen up at 250,000. (just fresh rings and bearings, no honing or turning whatsoever, no new lifters, pumps or anything) When the original Toyota factory parts started to go bad (they lasted 21 years by the way) and I had to start getting aftermarket water pumps and alternators and stuff...well now it's a yearly round....hey , starters out... time to start shopping for a water pump...then alternator...voltage reg....bulbs(just replaced all the original interior bulbs that lasted over 40 years and still worked but were getting dim)...shocks....once you get it all replaced , start shopping again. Report
May 1, 201313 yr comment_654957 yea dwell angle is the way to go. 4k : 52+- 6 deg but if using feelergauge, toyota K manual suggests to adjust to 0.45mm rubbing block gap. That way pittings and lumps on points doesnt affect the measurement. Renew if bad tho Report
