October 11, 201412 yr Author comment_689324 Bit more being done, this time the top arms being done and now all linked up and quite rigid, Tested tyre width and seems 255 wide tyres fit, and could go wider when the leaf's are dropped out Next is to fit these bad boys to pull her up Report
October 27, 201412 yr Author comment_689938 So rear end is mostly complete, just to fit the Gaz coilovers all round to position the ride height for the wheel offset, and Brembo's are on Report
October 28, 201412 yr Author comment_689995 Enough looking at the rear end, up front the SR20 has been remounted on the Escort rack and pinion, Escort crossmember has been lowered 20mm Gearbox crossmember redesigned also, same idea Report
November 20, 201412 yr Author comment_690926 While the Cortina is being finalised and back on the ground, Getting more pieces for the engine, More suitable intake as the S13 bannana log is rubbish and a top mount manifold that is more aesthetic Next is to mount it up and see if it fits, yeah I'm a bit worried i might not.... Report
November 24, 201412 yr Author comment_691089 So figured it was time to bolt some of these things together, surprised it fits, clears and fills her up And got the GAZ Coilovers in with adjustable tops Chucked on some wheels to see confirm the offset, these are no the rims, but are 18's Prolly should go 355mm front rotors i think Report
November 24, 201412 yr comment_691092 Looking good Carlos! That's tight! Being a small engine bay................will heat be a problem? Cheers! Report
November 24, 201412 yr Author comment_691099 Looking good Carlos! That's tight! Being a small engine bay................will heat be a problem? Cheers! Cheers matty, ill prolly thermal coat the hot side to contain the heat, or do your trick and park it in the shed forever haha Report
November 24, 201411 yr comment_691107 Very nice work mate. You doing all the welding/fabricating yourself? I still see you are rockin' that quote in your signature, that is going back a few years now! Report
November 24, 201411 yr Author comment_691114 Very nice work mate. You doing all the welding/fabricating yourself? I still see you are rockin' that quote in your signature, that is going back a few years now! Hey Dave, yeah was a great day that one, and shows how diverse and all sorts we are haha, since you were last in NISROLA, the Cortina will be more fun, and cause it will be street driven I don't have the required skills to have it all signed off by the engineer, but he does an awesome job tho Report
December 17, 201411 yr Author comment_691948 So updates I better share on the forums as opposed to FB Rear end is complete with coilovers, and 6 link Gussets are done also, make it more rigid 18inch rims fit are the minimum these days, and 300mm rear rotors Report
December 18, 201411 yr Author comment_691991 Alright some other things i don't know what they do Report
December 19, 201411 yr comment_692013 I really hope you finish this beast, will be a wild turnout (if its the same idea in my head!), and keep those pics coming, loving it!!! Report
