Sznaps Posted November 5, 2013 Report Posted November 5, 2013 (edited) Hi guys, Plenty of awesome engine conversions here. I decided to detail how going from 4agze to 4agzte went in my case - maybe it will encourage somebody to go this way too (or opposite ;-)). Got plenty of pics from this build - will try to document all when time allows. This topic will contain only materials related with twincharging - more pics and vids regarding my rolla can be found in this topic (http://www.rollaclub.com/board/topic/63701-ae82-twincharged-corolla-sznaps/) where i put in general all updates of my twinky. The system is completed and in use for over a year now. Mostly street use but been on couple of track days and I must say I am completely in love with it and it did not cause me any problems so far. There are many scattered and not finished/forgotten twincharged info/projects in internet - would like this topic to cover all from start to the end showing working and quite satysfying outcome with no uncertainities of what would the result of such combination be. I think there are people who could find it useful - When I was gathering info and how-to I was really struggling with finding complete description of such project and even twincharge users impressions so it was a bit like walking in the dark. I hope you will find this topic interesting. The starting point is already swapped 4agze from levin AE101 gt-z. The engine is stock with TMIC with two exceptions: - it has 175mm crank wheel to have supercharger spin faster (it makes at peak about 0.8bar) - it has piggy back to fool oem ecu not to retard ignition at 5500rpms (standard problem with bigger crank pulley) at this point engine makes 182hp Edited July 10, 2014 by Sznaps Quote
Sznaps Posted November 5, 2013 Author Report Posted November 5, 2013 first and most important part is of course turbo. I picked EVO X turbo td05h-152g6-12t And first impressions that with standard radiator it will he rather hard to fit it in. Quote
Hiro Protagonist Posted November 5, 2013 Report Posted November 5, 2013 - it has piggy back to fool oem ecu not to retard ignition at 5500rpms (standard problem with bigger crank pulley) I think you'll find that problem isn't isolated to overdriven superchargers, I know lots of guys here in Aus who have had dramas with ignition cut at 5500rpm in the AE101 GZEs stock, from memory it is due to the knock circuit being extremely sensitive to particular harmonics in the GZE engine (quite possibly related to the supercharger though) - even switching knock sensors AND ECUs (to a 7MGTE and AE92 GZE respectively) didn't fix the issue 100%, which seems to indicate the harmonics are a fundamental issue of the engine itself. Quote
Sznaps Posted November 5, 2013 Author Report Posted November 5, 2013 The idea was to get rid of standard radiator and replace it with smaller one - honda style from ebay with thin fan. It would be placed next to turbo (not in front of to make more space) Other goodies that were gathered in advance were: The intercooler: Bigger injectors - I picked 440cc 7m-gte injectors Quote
Sznaps Posted November 5, 2013 Author Report Posted November 5, 2013 Hi Hiro, Yes I think there are many factors here. I had 5500 problems and even have my dyno with it where you can see how drastic the cut is: Fortunately piggyback and its tuning solved the problem for me completely (see earlier dyno - it was after piggy backing) Quote
Sznaps Posted November 5, 2013 Author Report Posted November 5, 2013 ok so at this point most of most important pieces to start with are completed. The idea for system in my case was: - supercharger blowing into turbo to spool it up quickly - turbo blowing into intercooler - after intercooler is throttle body - when turbo is fully spooled up - supercharger would be disengagedto avoid extreem air temperatures at high revs (roots is quite a heater) and get rid of parasitic supercharger toll on engine - beta stage of system was supposed to be without bypass valve so turbo is always sucking air through supercharger (always so when supercharger is on or off) - final stage was to be with bypass valve which would be opened at the moment supercharger is diengaged - that would allow turbo to suck nice cold air without resistance that sucking through supercharger creates To sum things up the system would be quite like the one in VW twincharged TSI engines - with small difference of placing bypass valve: Beta stage without bypass valve: Final stage with bypass valve: Quote
B.L.Z.BUB Posted November 5, 2013 Report Posted November 5, 2013 Is the ignition retardation issue for both dizzy and DLI engines. This is news to me, and I'm about to put the nevo pulley on. Quote
Sznaps Posted November 5, 2013 Author Report Posted November 5, 2013 I think the problem is common for ae92 and ae101 agzes so that would mean DLI am I right? Quote
Sznaps Posted November 5, 2013 Author Report Posted November 5, 2013 please be patient I would like all updates to be in correct order so I will just say that I used Nissan electronic throttle body for now;-) will update this topic regullary when possible but I think in a week i will input all I have here. Quote
B.L.Z.BUB Posted November 5, 2013 Report Posted November 5, 2013 I think the problem is common for ae92 and ae101 agzes so that would mean DLI am I right? Yeah, thats what I thought. I was going to pester you about this conversion and now I wont have to. Be prepared for many questions :) Quote
Sznaps Posted November 5, 2013 Author Report Posted November 5, 2013 hell no!...looking how to delete the topic now :-) Quote
Hiro Protagonist Posted November 5, 2013 Report Posted November 5, 2013 More prevalent on the AE101 engine I think, which has slightly higher numbers (+4kw) Quote
Sznaps Posted November 6, 2013 Author Report Posted November 6, 2013 first thing is first - weighting td05 turbo - 14kg - to compare sc12 supercharger is about 12kgs (I think I was weghting it but long ago) turbo disassembled to turn hot and cold side to fit available space (and get ready for piping) Quote
Sznaps Posted November 6, 2013 Author Report Posted November 6, 2013 last look and lets cut her open Quote
Sznaps Posted November 6, 2013 Author Report Posted November 6, 2013 Turbo positioned so lets go with exhaust manifold Quote
