Little Red Rolla - Ke10 Build
Thanks a lot parrot!
I'm not completely sure can I bend the bar anymore without it losing its spring. Also I have to call to a friend of mine to make sure this is legal here in Finland. Only thing I think might be illegal is to drill holes to lcas.
When I get the info I'll decide if i try to bend it or do i use the bracket idea i got yesterday as it doesn't need any new holes made.
Do you think it will have somekind of geometrical issues if the bar is 5-6cm forwards of the control arm? Stiffnes is not a problem in the design i have in mind.
  • Replies 77
  • Views 285.9k
  • Rollake10
    Rollake10
    Today (9.4) Was a good day. Perhaps my birthday and that I got my license had to do something with that ;) This day has gone cruising with my dads E60 8D   But to the Corolla! As always I've been bu
  • Rollake10
    Rollake10
    Thanks! I think I need to forget all the aftermarket carbies for a while as they are quite expensive.   I've been trying to get the car running smooth with the stock aisan.. car runs quite well when
  • Rollake10
    Rollake10
    Little Red Rolla finally worth its name! ;)   This is just a picture that the painter sent me. Haven't seen it yet.. Going to get it home next Friday i'm super excited!
Stuart and Tommy (tommys KE11) helped me out after dealing with the issue themselves. I think from memory they had to modify a bar that touched on full lock, requiring the pedal to be pumped to bring the pedal back.  Check their very entertaining build thread, I expect the answer is there.
  • 3 years later...
don't mind me too much, just wondering how the little rolla is going.
I decided that after 1o years of sittiing arround I should start work on my little rolla and found your post.
