maccat01 Posted April 2, 2014 Report Share Posted April 2, 2014 Hello all. I recently purchased a recod 2 speed toyoglide for my 1976 ke30 sedan. Fitted up all good until I tried to connect tail shaft. It seems my old gearbox and tail shaft have 19 tooth spline, whereas the new gearbox has a 15 tooth spline. Help in this mater would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
maccat01 Posted April 2, 2014 Author Report Share Posted April 2, 2014 Does anybody have a manual for the two speed as I'm hoping I can remove the back of the box and swap the output shafts over. But ive pulled my old box apart and it appears to have one shaft running the whole length of the box :-O Quote Link to comment Share on other sites More sharing options...
camerondownunder88 Posted April 3, 2014 Report Share Posted April 3, 2014 I know early KE1X and KE2X had a different drive shaft to later model cars. KE30 came out with the 3 speed auto. Dare say it is get a 3speed box or see if you can adapt a smaller early KE1X yoke to late model drive shaft. Will handel less power and 3speeds are every where so dare say wont fit. Cameron Quote Link to comment Share on other sites More sharing options...
Clapped out Posted April 3, 2014 Report Share Posted April 3, 2014 (edited) Early ke30's DID come out with a 2 speed auto, and yes the output spline between the early and late 2 speed auto's are different, cheers! Edited April 3, 2014 by Clapped out Quote Link to comment Share on other sites More sharing options...
oh what a nissan feeling! Posted April 3, 2014 Report Share Posted April 3, 2014 change the tailshaft yoke at the uni, gearbox output shaft is removed from the front of the box, last thing to come out. Quote Link to comment Share on other sites More sharing options...
philbey Posted April 7, 2014 Report Share Posted April 7, 2014 Yep. 80 bucks to swap yoke and rebalanced with new unis when I changed mine to manual. Yoke was scored from a wrecker for 15 bucks Quote Link to comment Share on other sites More sharing options...
camerondownunder88 Posted April 7, 2014 Report Share Posted April 7, 2014 Early ke30's DID come out with a 2 speed auto, and yes the output spline between the early and late 2 speed auto's are different, cheers! Well ill be dammed...2speed ina KE30. Never knew this but good to know thanks for the correction. Looks like it is an easy yoke change and were on the road again Quote Link to comment Share on other sites More sharing options...
67Rolla-Ken Posted April 7, 2014 Report Share Posted April 7, 2014 I have the 1100 Toyoglide Auto Service manual if you need to see any pages. I believe it's from 1967 and it looks like it hasn't been opened often so not keen to try and scan all the pages. Happy to take pics of needed pages. Quote Link to comment Share on other sites More sharing options...
KeTen Posted April 7, 2014 Report Share Posted April 7, 2014 I had ke30 2speed auto in my ke10 then changed to ke70 5speed it used the same yoke if that helps. Quote Link to comment Share on other sites More sharing options...
