Te27 3 Gauge Cluster Plug
Obscure post of the month
If you have bought a 3 Gauge TE27 centre cluster to retrofit into your KE2x and need the plug, it is identical to that found in the dash wiring of a 1975 MS85 Crown.
I realise MS85's don't exactly grow on trees, but neither do TE27's
I figured I'd just be able to buy a new generic plug when the time came to fit it all up.......??
Fraid not. If you look at the speedo/tacho cluster round wiring plug, it is a smaller 6 pin version of that.
I'm sure you will work something out. You can cannabalise the terminals from a KE2x dash cluster, or find a modern terminal equivalent. But the plug isn't something you can get off the shelf.
interesting..........oh well I know a guy.......
Thanks for the info
  • 4 months later...
Hey parrot,
Any new alternatives to this scenario for the centre gauges? Any other cars with similar plug? Something from jaycar?
Just picked up a te27 cluster, tacho section working, was also wondering why the hazard toggle also has two click options when you twist it...?
Mitch
No. A plug will be factory or nothing. Someone here was wrecking an MS85 recently.
http://www.toymods.org.au/forums/threads/85475-Wrecking-1980-MS85-Crown-Super-Saloon
Failing that, look out for similar era imported higher end Toyota's such as the fancy Corona of the time. It will need to be an imported car I reckon, not AMI built
i have a MS85 sitting form my RS50-->MS50 build... PM me if you want anything :)
ah well this is where making bits off different cars fit where they were never intended sometimes pays off.
find a mitsubishi l300 van. pull the cluster. There's your plugs. easy to find
  • 7 months later...
I had the same problem but wired up every thing with these wires bullets. It worked fine till eventually i found a plug but still worked with them. If them do not fit exactly just press them a little get them more "roundly"
  • 9 years later...
Hey Parrot,
Any chance of a clearer photo of this 3 gauge cluster plug so I can see which wires go where?
As you can see from one of the photo's above, the pins are numbered consecutively 1 - 6.
Wire colours are as follows.
1. Yellow / Black
2. Yellow / Green
3. White / Black
4. empty
5. Red / Black
6. Yellow
I haven't made any effort to workout where they go
Unfortunately the centre cluster gauges don’t appear in the wiring diagram. These photos may or may not assist.
Batsuteri is battery.
I have no idea what N, B, F and E represent unless they are printed on the circuit board.
IMG_0528.thumb.png.42aee819fb0333b767799929d85773a2.pngIMG_0529.thumb.png.e421e56b3c23f98ad05837d5dff38f88.pngIMG_0530.thumb.png.6b6473126e2dffbb46d0647801a6f610.png
