January 10, 201610 yr comment_702316 As the title says it all, I just want to know if its possible to put that gearbox behind the 4A-FE car by engine? Don't care if the gear is not strong enough or should I go for T50 blah birdy blah blah. Regards Syed Abdullah Mohsin DAISTEP Report
January 11, 201610 yr comment_702333 Only if you can find a K to T bell-housing. They were made for a few years and second-hand ones are still around occasionally. They allow you to put a K gearbox behind any 4A block, as far as I know. Report
January 11, 201610 yr comment_702338 it will fit if your k50 came from a A engine but not if its from a K engine- 4a-fe in RWD will cause Dizzy and manifold issues Report
January 11, 201610 yr comment_702344 Isnt k-t gearbox adaptor for putting a t series gbox behind a k series engine? This guy wants to put a k series gbox behind an a series engine. K-t adaptor won't help? I've never heard of a solution to adapt a series engine to a k series box. Report
January 11, 201610 yr comment_702347 I've never heard of a solution to adapt a series engine to a k series box. AE85 had a K50 behind a 3A... Report
January 14, 201610 yr Author comment_702400 Correction my mud box is a k40 from a 4k engine. My 4k died or I rather say killed it now i'm pissed because the repairs are to costly and the engine as well cost me higher than a 4afe or a 4age. Ironic right? A 4k price higher then a 4age and other 4a engines. I have parts and stuff like distributer flywheel etc etc let me know if someone is interested in buying these spare parts. Back to the topic again. I read it somewhere on the forum (not this one though) that a k40 or k50 can fit a A series engine without a hunch is that true? Report
January 15, 201610 yr comment_702409 Back to the topic again. I read it somewhere on the forum (not this one though) that a k40 or k50 can fit a A series engine without a hunch is that true? The issue you'll have is that K-series boxes have integral bellhousings - ie you can't swap bellhousings to suit the motor you want, a 4K K40 won't have the same pattern as a 3A K50. Report
