September 10, 201610 yr comment_706269 So I have a 79 Corolla with a K series transmission, and I had heard that the Starlet transmissions were the same. I was just wondering if an 82 Starlet transmission would fit into my car (79 Corolla). Thanks! also if this is in the wrong section let me know Edited September 10, 201610 yr by 79gooser Report
September 10, 201610 yr comment_706271 82 starlet would be fwd. You need to look for one from a kp starlet Report
September 10, 201610 yr comment_706280 They made KP's till '84 taz. If it's a k50 it'll bolt up to the engine, you may run into crossmember and gearstick location issues. Report
September 11, 201610 yr Author comment_706298 They made KP's till '84 taz. If it's a k50 it'll bolt up to the engine, you may run into crossmember and gearstick location issues. Thanks for the info! Do you know what sort of gearstick location issues, like will I have to move it forwards or back? Report
September 11, 201610 yr comment_706299 Since Your 79 Corolla is a ke30 there wont be any location issues. Same shifter location as kp6# A wide range of corollas were made in 79` ;) Report
September 13, 201610 yr Author comment_706321 Since Your 79 Corolla is a ke30 there wont be any location issues. Same shifter location as kp6# A wide range of corollas were made in 79` ;) Awesome! Hopefully it will be back on the road again soon, thanks all for the help! Report
March 8, 20179 yr comment_708429 Would this work with starlet engine but corolla box? (looking at the GT engine ofc) Report
March 8, 20179 yr comment_708435 Would this work with starlet engine but corolla box? (looking at the GT engine ofc) Are you referring to the EP71/EP82 Starlet GT? That's FWD with a completely different engine and transmission compared to what the OP was referring to (RWD and K-series) Edited March 8, 20179 yr by Hiro Protagonist Report
