Novica94 Posted July 17, 2018 Report Share Posted July 17, 2018 Fellas, Does anyone know where i could find a Vacuum Diagram for the 3k and 4k engines? Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted July 17, 2018 Report Share Posted July 17, 2018 This one? Quote Link to comment Share on other sites More sharing options...
Banjo Posted July 18, 2018 Report Share Posted July 18, 2018 Oh I hate all those little rubber hoses that go hard & crack & leak ! What a nightmare to test all those little actuators, & one way valves. Came across one once so bad, I ripped all the "decrepit" hoses off to replace them, only to find someone had placed a ball bearing tightly in each hose, to make it look right, but totally inoperable. Cheers Banjo Quote Link to comment Share on other sites More sharing options...
peterd Posted July 18, 2018 Report Share Posted July 18, 2018 44 minutes ago, Banjo said: Oh I hate all those little rubber hoses that go hard & crack & leak ! What a nightmare to test all those little actuators, & one way valves. Came across one once so bad, I ripped all the "decrepit" hoses off to replace them, only to find someone had placed a ball bearing tightly in each hose, to make it look right, but totally inoperable. Cheers Banjo I've read about that. It was a way to trick the cops so you didn't get a defect notice for not having every factory. Quote Link to comment Share on other sites More sharing options...
ke70dave Posted July 19, 2018 Report Share Posted July 19, 2018 You would have to get a very savy cop to even know what a vacuum line was! In my limited experience the 3k and 4k carbies are different. the 3k one has like 2 vaccum ports and the 4k has about eleventy billion. I put a 3k carby on my 4k years ago to remove all the vac lines, looked factory cause it was:) Quote Link to comment Share on other sites More sharing options...
Banjo Posted July 20, 2018 Report Share Posted July 20, 2018 Hi Dave, You've always been a great innovator ! I like it ! Cheers Banjo Quote Link to comment Share on other sites More sharing options...
ke70dave Posted July 20, 2018 Report Share Posted July 20, 2018 Haha yep. That was back when wreckers were full of 3ks and 4ks. These days you'd be lucky to find any. Though i made the mistake of not putting the 4k jets in the 3k carby. It ran fine but i reckon it was a bit lean up top. 1.2L vs 1.3L not much difference but i think enough to require bigger jets in the 3k carby. Quote Link to comment Share on other sites More sharing options...
