August 26, 20188 yr comment_715356 Gday, I'm a new member based in Qld Australia. I have fitted a new T50 gearbox and when I fill through the filler plug I can only get 1 litre into the box before it is running out. Manual says it should hold about 1.6litres. Any help most appreciated. Cheers, thanks, regards Evan Report
August 26, 20188 yr comment_715357 Hi Evan Welcome to rolla club ,you will find that the t50 capacity is around 1.7 litres according to castrol and valvoline net lube. I can't remember putting much more than that, if that much. https://www.datateck.com.au/lube/castr_au/ https://www.datateck.com.au/lube/valv_auMS/ i guess its a rwd? cheers rob Edited August 26, 20188 yr by corollaart Report
August 26, 20188 yr comment_715358 A 4A type RWD T50 is 1.7 litres as Rob said. A 2T type RWD T50 is 1.5 litres. Where are you filling it from, the fill plug in the side of the box, or through the gearstick hole in the extension housing. If the latter, you generally have to be pretty patient and let oil drain away before adding more. Report
August 26, 20188 yr Author comment_715360 Thanks guys RWD 4A. I’ve filled through the side hole. Let it sit for two weeks on level ground while I was away at work. Tried to add more when I got home. No joy. 1 litre that’s it then it starts running out. Starting to do my skull in. Report
August 27, 20188 yr comment_715366 Are you sure it was empty when you put it in?? Did you drain it then? You could drain it, put the plugs back in and pour 1.7L down the gearlever hole, which is what I did when I couldn't get the filler plug out.... Report
October 27, 20197 yr comment_720458 If it were me I'd drain all the fluid by removing the lower drain plug , i think it takes a 17mm wrench to fit the drain plug . Remove the shifter from the tranny and the side filler plug whitch takes a 15/16 " or maybe a 22mm socket or wrench. After all the fluid has drained be sure to install the drain plug ! Fill through the shifter hole slowly until you see fluid coming out of the check/ filler plug . Report
October 27, 20197 yr comment_720459 "the side filler plug whitch takes a 15/16 " or maybe a 22mm socket or wrench. " That's the problem! The skinny nut they used just rounded off, tucked up against the transmission tunnel & exhaust, and I've never got it loose since. So its drain plug and a measured amount through the gear-lever for me. Report
October 28, 20197 yr comment_720469 Okay your next step is to Heat the area around the plug area with a tourch , then strick the plug to shock it , then use a chisel and hammer striking on the plug to jar it loose . Remember the plug unscrews counterclockwise ! If you get that plug out discard it and replace with new one . Hope this helps Report
October 31, 20196 yr comment_720497 Not so easy if the gearbox is still in the car though! Pig of a job pumping viscous transmission oil whilst scrunched up under the car, trying to see what you are doing inside the transmission tunnel Report
