September 13, 20188 yr comment_715454 Hi I'm just browsing around Toyota cars with the Carbie 4A-F. Appreciate it is now 'old tech' but lots of miles run on them so lots of techhie info will be about here.... I post on ToyotaNation (toosavvy, Brit in Bitz!) so perhaps you guys look in on there ?? 4A-F Edited September 14, 20188 yr by 4A-Foottotheboards edit Report
September 15, 20188 yr Author comment_715468 ....... Further to the above ...... http://forum.alltracwagon.com/cgi-bin/forum/Blah.pl?v-print/m-1301874383/ This sort of thing When did anyone see such a thorough 'hop-up' on this Corolla/Carina motor ? (well, its the only one I can find!) 4A-F Report
September 17, 20188 yr Author comment_715493 I understand the 4A-FE (2nd gen) had greater cam lift [7.6MM] than the dimensionally identical 4A-F Carb head. Anyone ever done a scrapyard upgrade this way.... ?? 4A-F Report
September 22, 20188 yr Author comment_715528 I have just ordered a Vdubb t4 'centre box' exhaust to replace my std factory 'stuffer' box... It is 50mm and a resonator/straight thru. See how it sounds, eh 4A-F Report
September 22, 20188 yr comment_715530 Carbs lined up to go with it?? DCOE Webers or Mikuni bike carbs? Report
September 23, 20188 yr Author comment_715536 10 hours ago, altezzaclub said: Carbs lined up to go with it?? DCOE Webers or Mikuni bike carbs? I plan the 'vac mod', to release the second choke for operation all the time, but no plans for dumping the AISIN. 4A-F Edited September 23, 20188 yr by 4A-Foottotheboards Report
September 23, 20188 yr comment_715537 I assume that’s the old “swap the spring from one side of the diaphragm to the other” trick. I’d forgotten all about that. We used to do that back in the 80’s club racing days. But soon it was a slippery slope to twin side drafts Ah the memories! Report
September 23, 20188 yr comment_715538 I should add, after a speed event we would swap the spring back so the second Venturi only opened as per factory, or you lose flexibility for around town driving. Report
September 23, 20188 yr Author comment_715539 Ah, the memories .... indeed I'm running a 'timewarp' '91 Carina II ..... These cars were default taxi/pizza delivery fodder 'bitd' >> then ovalled to death! I'm not going Rat or Scene.... (I'm 61!!) Just taking advantage of a bit of swappability & OldSkool mods. When I get the bus pass I'll likely move on to Mamod steam engines. lol 4A-F Report
September 23, 20188 yr comment_715540 Well, this might be your last chance! Better than sex.... Report
September 23, 20188 yr Author comment_715541 Ha ha.... I'm up 2 speed on OZ surf scene! I know the difference between a 'woodie' and a Woodie https://goo.gl/images/mabvVV ... why do you reckon my RicePipe is for a t4 Lovely presented piece of automobilia m8 [/thumbup] Edited September 23, 20188 yr by 4A-Foottotheboards Report
September 23, 20188 yr Author comment_715542 2 hours ago, parrot said: I should add, after a speed event we would swap the spring back so the second Venturi only opened as per factory, or you lose flexibility for around town driving. Yes, it has been commented elsewhere that the 'factory' is best for street. My plan is to 'temp/bodge' the rod lift (disabled mode) by attaching a slotted arm to the rod - not unscrewing anything on the carb body - the slot in the arm will *'bite' the rod [due to the twist force] and a strong spring hooked to the arm end. This is turn on/offable for me to run at will, or not! *beetle lift jacks use the same principle to 'walk up' the jack leg. 4A-F Edited September 23, 20188 yr by 4A-Foottotheboards Report
October 8, 20188 yr Author comment_715674 I have ordered some exhaust putty, good price + free pp, on eBay. Popped into Halfords Auto Centre and got 4x U-clamps for £1.60 each = cannot find any cheaper option on the web. I will have to form a bend/join - over the axle - so having pre formed bends, in the original part is an 'extra bonus' 4A-F Edited October 8, 20188 yr by 4A-Foottotheboards Report
