ke30/35 meter cluster light
hello guys , been wondering on how to add led light in the meter cluster like the attached picture , i got this picture from fb but forgot whos the owner of this picture. if you guys have done this modification or have any ideas , please share . thanks in advance .
1283293996_ScreenShot2017-12-21at5_55_25PM.thumb.png.8c009c302496bcc2dcfd82d6884906e9.pngano
I’m sure it has been discussed previously, not necessarily in a KE30 but the concept is the same no matter what. You will have to search the forum for the threads.
May be easier searching in google but add rollaclub to the search terms for forum specific threads
edit: and when you find it, add a link to it here so it’s easier to find next time
Edited by parrot
Here's a link to one I remember recently.
https://www.rollaclub.com/board/topic/73225-smarten-up-your-dash/?tab=comments#comment-708509
Here is another . . .
https://www.rollaclub.com/board/topic/51690-rosie-the-ke55-rolla/?page=4&tab=comments#comment-540580
Just Search Rollaclub above field for LED or T10, & a few will come up.
Cheers Banjo
Edited by Banjo
Cheers Banjo
thanks for your help @Banjo , the 2nd link is nice idea!! never thought about it , just lay the led strip inside the meter cluster. thanks for your help @banjo and @parrot
just want to share my upgraded meter cluster to led , thanks for the idea guys .
bought the led strip from local store , here's the sample picture
IMG_6326.thumb.JPG.d1b19b1356d29922e28784ae88f72363.JPGIMG_6325.thumb.JPG.94987c937bb7b0d4145807dc5f6b8bc7.JPG
at first i planned just to lay the led down like the link you shared but i just stick the led strip all around the corner since it has a little bit of space which it fit perfectly. for the wiring , i just soldered it directly at the t10 bulb socket (red wire to positive side and black to the grounding side) and that's it .
here is the before and after
before, with t10 led
IMG_6318.thumb.JPG.083e4b2a7a58724e13c18a5861f4d4c8.JPGIMG_6319.thumb.JPG.56a1700d88d79bb29a04d83f12d977b3.JPG
after, with led strip ( the colour slightly off maybe because of my camera effect , actually its pretty nice in reality , you get the idea)
hopefully this thread will be helpful to those who wanted to upgrade their meter cluster light . thanks for the idea @Banjo
Edited by saif317
That's brilliant !   Probably a little bit too bright.  I got a roll of those LEDs.  They are great.  Use them for various lighting requirements. You can build a simple dimmer for LEDs, using a variable Pulse Width control.  Plenty of circuits on the net.
https://www.youtube.com/watch?v=n48GemL7tsc
Cheers Banjo
Edited by Banjo
I was thinking the exact same thing. I wonder how many members will get the reference. Classic.
Hi Graeme,
                    I'll put my hand up.  I had to Google "Corey Hart" to see who he is, & what the reference referred to.
Quote
Corey Mitchell Hart (born May 31, 1962) is a Canadian singer, best known for his hit singles "Sunglasses at Night"
Brilliant Dave !
Edited by Banjo
Cheers Banjo
thanks for the tips bro , well actually it's not that really bright .. as mention before, maybe it's just the camera effect that made it looks pretty bright in picture. in reality , to me its not that bright. another tips for those who wanna reduce the bright , you might want to use less led compare to mine.
