frosty Posted October 27, 2022 Report Share Posted October 27, 2022 Has anyone had this happen and the likely cause and a remedy" ke70 5 speed locked/jammed (immovable) in first gear new box or fixable? I have no idea lol Quote Link to comment Share on other sites More sharing options...
ke70dave Posted October 28, 2022 Report Share Posted October 28, 2022 Well there is not too much too gearboxes, but unless you somehow manage to wrestle it free via the gear stick its going to be a gearbox removable and disassemble to fix it. Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted October 28, 2022 Report Share Posted October 28, 2022 Bound to be fixable, most likely the 1st gear selector is either broken inside the box or wore the tips out so much it has jumped off the gear. How does the gear lever feel? More sloppy than usual? Jammed solid? In the usual place for 1st gear or further forward/backward? Quote Link to comment Share on other sites More sharing options...
frosty Posted November 1, 2022 Author Report Share Posted November 1, 2022 seems to be jammed solid Quote Link to comment Share on other sites More sharing options...
frosty Posted November 2, 2022 Author Report Share Posted November 2, 2022 (edited) It went from reverse to first and then stuck there Can move the gearstick as if it is in a mixing bowl. Could of the ball on the bottom of the gear stick broken off - is that even possible.?? Havent looked at anything yet as car is about 100 k's from home when it broke down. Edited November 2, 2022 by frosty spelling Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted November 2, 2022 Report Share Posted November 2, 2022 "Could of the ball on the bottom of the gear stick broken off" Yes- About 50years ago I put my Lotus Europa in for service and they broke the bit off the bottom. I found it had happened before & been welded, but the mid-mounted North-South engine had a torturous path to the gearbox and a lot of stress on the lever. There's a couple of other spots where a pin could break or selector jump out, but you'll only find out when you strip it. Start with the getting the gear lever out & have a play with the selector rods before you pull the whole box. Quote Link to comment Share on other sites More sharing options...
frosty Posted November 4, 2022 Author Report Share Posted November 4, 2022 On 11/3/2022 at 7:45 AM, altezzaclub said: "Could of the ball on the bottom of the gear stick broken off" Yes- About 50years ago I put my Lotus Europa in for service and they broke the bit off the bottom. I found it had happened before & been welded, but the mid-mounted North-South engine had a torturous path to the gearbox and a lot of stress on the lever. There's a couple of other spots where a pin could break or selector jump out, but you'll only find out when you strip it. Start with the getting the gear lever out & have a play with the selector rods before you pull the whole box. OK, thanks for the idea, will see how that goes. Quote Link to comment Share on other sites More sharing options...
coln72 Posted November 4, 2022 Report Share Posted November 4, 2022 have had the pin in the selector shaft break during an event locking me in 2nd. pulled the shifter and tried to fit a splitpin but dropped it into the box 😞 ended up scrapping that gearbox. 1 Quote Link to comment Share on other sites More sharing options...
