October 6, 200619 yr Author comment_145092 I borrowed an electrical pipe bender from my work to do the second pipe of my strut brace, not the first time I have used one of these benders for a project. It only needed a slight bend either end and is yet to receive the reinforcing supports because I am still making them. It also still only has temporary welds holding it together for now. It was far from easy to do though as the first bend I did kinked straight away, so at each end I had to bend in two close together sections. Heres how it looks: All in all it has been a very tricky project but so far the work has really been worth it seeing that it's rock solid and weighs under 1.5kg so far. I still have a fair bit more work to go though. this is one of the flat sections of plate that I used to make my brace before I welded it: It took me a considerable amount of experimenting to make these pressed holes properly. Using a lathe I made up a special die and 2 punches to get the right shape. I did it with one punch initually but the force on the metal was too mcuh and it was warping the steel, so I made a starter puch that had a gentle angle. I can post some pics of this if people want to see it. To punch these holes the way that I decided to do in the end I have to follow these steps: - Mark out holes 30mm apart on some steel - Center-punch - Pilot drill small hole - Drill a hole a 13mm hole - Deburr hole - Place my die under the hole, and place the starter punch into the hole - Using a press push the starer punch in and remove - Change to the finishing punch and press All this about 50 times, oh yes I am patient, but I can do it pretty quick now. One of the problems I had was that I couldn't drill a 13mm hole into the sheet metal, if it wouldn't make a triangular shaped hole it would rip at the steel, try and pull it out of my hand and leave a rough hole. So what I did is regrind the tip of a drill bit to have a very sedate cutting profile on the tip, you could almost call it purposefully bluntening it. After I did that it would slowly cut through and leave a perfectly round hole without ripping at the material when it went through. Regardless of how I acheived it the results I was quite happy with. During my trial peices I would start with a floppy peice of sheet metal and once I had stamped all the holes it would become quite rigid, and all while I had actually removed material from the sheet... funny My strut brace is now finished and bolted up, i will have pics soon. Also for anyone who is interested I bought my Cro-Mo from a place called Airport Metals. There are very few places selling 4130 grade steel so I thought I would post the info here for anyone else who is interested. Airport Metals 26 Lillee Cresent Tullamarine Vic (03) 9310 5566 http://www.airportmetals.com They also sell some other exotic materials like 6013-T4 Aluminium, Titanium and even Hastelloy. now for something different, I did this a while back but I might as well post it seeing its related to my car and someone might like the idea. When I was living at my previous place I found I needed alot more light to work on my car so I was going to buy a worklight from the warehouse. Finding that they only had high wattage hallogen fittings at the time I decided to make my own. I bought a pair of batten holders and spent some time designing something. I decided that not only would I have something that could be adjusted to light up my engine bay it would also be adjustable to fit under a car or over it. So I bought one tiny normal castor wheel and two slightly larger castors with a brake on them from Supercheap auto. I made up most of it in an afteternoon and wired the rest up later. I initually only wired up two globe fittings due to a shortage of batton holders at The Warehouse store and I also used energy saving globes for a nice white light. The next day after leaving it at my place I found my other roomate at the time using it to paint part of his car, so he obviously liked it. With the four fittings now in place it is a bit bulky but it does a very good job and I use it all the time. Also as a bonus it cost me like under $30 for everything. Heres some pics: Edited November 26, 200619 yr by Sam_Q Report
October 6, 200619 yr Author comment_145093 took a pic of my brace which I installed this morning. it ended up stronger than I expected, when I try and push it with all my weight I can't feel it flex even a few mm . Also the final count for the weight is: 2.4KG!!! Needless to say I am pretty happy with this. Edited June 15, 200719 yr by Sam_Q Report
October 9, 200619 yr Author comment_145538 thanks for the feedback guys, I am very open to any ideas or sujestions if anyone has any. It might be a bit of a while till I get a chance to do more work though, I am in the middle of fixing a car up for my partner. Report
October 10, 200619 yr comment_145661 one word, pure tallent. oh thats 2 what the hell :y: you can come work on my car any day (for free) Report
October 10, 200619 yr Author comment_145664 not so much tallent as persistance, stubborness, a crazy amount of patience and a perfectionist attitude (to my standards). For anyone looking at my work and thinking its really something then keep in mind that I have been working on this almost non stop for 3 years now. I am constantly fighting my time and energy levels, its a real struggle, but I try hard. casey: theres a bit of water between me and you unfortunetly. So is it true theres heaps of fun cornering roads in Tassie? Report
October 10, 200619 yr comment_145702 yep pretty much, sidelen(spelling) the road from launceston to scottsdale, damn fun if your with some one who will give it a squirt,sadly thats only ever been once or twice with me in the car, other times i just throw up in the car :y: Report
October 11, 200619 yr comment_145971 been to tazzie the roads ROCK!!!!!!! pitty most of them end up with a drop to death Report
October 12, 200619 yr comment_146063 I love the road's around the mountain south of hobart towards huonville / dover. There's some real nice bends, such a pity it's wet most the time. I should do another road trip down sometime to visit my mate in launy. Report
October 12, 200619 yr comment_146081 You guys want winding hilly open roads come to beaudesert and do a ummm nice cruise. :y: EDIT: By the way your quality of work is mind blowing and your imagination is not to be reckoned with. Would you be interested in making another strut brace to suit a ke70? Edited October 12, 200619 yr by too quick Report
October 13, 200619 yr Author comment_146300 oh thanks, unfortunetly this strut brace took make an obscene amount of time and also I had to weld it on the car to make it fit. I think that it is such a one off that it probably wouldnt even fit on many other sprinters. I really wish I had time to do work for other people for both PCs, cars and electrical but I have to decline, I am drowning in work I have to do for myself and ontop of all that I occasionally get to do a little bit of work on my car. One day I don't know how but I want my own workshop, then things will change. I am starting now though I have decided to make a small amount of 20v rear bypass plates cheapy for people to see if they will sell. I have almost finished the jig for it at work. Report
November 7, 200619 yr Author comment_149922 I haven't been able to work on my car much lately but I have done a few smaller things on the side: - I now have made a small batch of RWD 20V bypass plates which are for sale for $50 each. Also I will be making side plates shortly. - I have continued to work on my own home-made gaurd roller. I have drilled out a huge plate for the hub and the roller is bellow. - I managed to buy a pair of Corona XT-130 lower control arms from the wrecker, i will be fully repainting and reconditioning them. I have already pushed the bushes out, ground off the steering stopers, pushed the ball joints out, cleaned + sanded + painted them, fitted new ball joints and I am working on doing the bushes. Heres how one looked when i bought it: Hopefully it will look like new once I am done. Edited December 20, 200619 yr by Sam_Q Report
November 26, 200619 yr Author comment_152455 right now my sprinter is no longer running. I was doing some wiring and somehow I killed my DLI module. I dropped it to the guy who built it and he currently looking into it. Other than that I still managed to do some work: I reran the wires for my coilpacks and also cleaned up my relay/fuse panel. and I finished my lower control arms: I did the following: - Started with XT130 arms - Chopped off the steering stoppers - took the ball joints out - took the bushes out - cleaned them - painted them - pushed new ball-joints and bushes back in I hope to install them soon, also they cost me a total of $35 each! Edited June 15, 200719 yr by Sam_Q Report
