HI I'm new here but have been lurking around for some time now.
This is my 1980 corolla wich I have owned for 3 years now but first started to work on about a month ago.
still a working project but will hopefully finish the mechanical stuff in 2-3 weeks
I'm putting in a Volvo B230FK engine and m90 transmission.
With 700cc injectors and 16t volvo turbo and about 18-20psi it will be around 250+ hp
All controlled with MS3
I used s13 running gear in the front but with custom made lower control arms.
s13 coilovers front and rear
I put a 1980 hilux rear axle and vw rear brake calipers and SSangyong musso brake discs.
some pics of the process
last year I had already fitted a ca18det engine and transmission, but when I took the engine apart I realized that the engine was blown.
had to cut a little bit into the firewall
not much room in there
test fitting the engine
finishing up the x member
Lca´s in making
AE86 tophats and a brake master from a MMC Pajero
and ofcourse hydrolic handbrake
refurbished s13 calipers
MMC evo 8 seats
radiator from a Ford transit diesel
16t turbo original from a volvo 850 T5
test fitting after making the lower brackets
and with tires
gas tank from a wrangler made to fit :)
everything ready, just waiting for the coilovers to arrive so I can finish the rear axle
in the meanwhile MS3 was connected up and it fired up and idled nicely in first try
Coilovers arrived and installed in the front
Edited by GretarK
  • Upvote 1
  • 4 weeks later...
here is more ;)
making room for the rear shocks
a pump bracket from a Subaru RS made to fit in the wrangler tank with a 255 walbro
steering rack in place, had to modify the oil pan a bit to make this work
Only lost 1L of oil capacity, which was added in the front
After finishing the oil pan the x-member was finished up as well
No room on the right side for the exhaust so I had to cut it up a bit.. again wink.png
Decided to make a side exit for the exhaust
All finished up
doing the intercooler piping
3,5" exhaust vs. 3" impreza downpipe
Engine out to finish up the bodywork in the transmission tunnel
The oil pan nice and shiny
  • Upvote 1
here is a small update.
made a bracket for the e-brake and passengers seat
aluminum plate for the hole in the trunk
tidied up the loom in the front and removed unused wires
rerouted the lighting loom
  • Upvote 1
brake clutch and gas pedal ready. Made the original gas pedal fit the volvo throttle cable.
This was originally automatic.
Moved the fuse and relay box into the car.
making finishing touches to the engine bay
the car handles great, still need to do some little tweaks
but I´m very happy with the outcome of this build
couple of pics from the 1st test of the car
  • Upvote 1
So.. we went out to make a few test runs and a fuel map for the car
and at 5000rpm in 4th gear this happened :/
we were lucky it didn´t go all the way through.
having a new stronger one made at the moment
