GretarK
Ke70 Corolla - Volvo B230Fk - Now With 2Jz :)
Well done man, love it! Any updates?
small updates at this point, ordered a new turbo cam and some maintainence stuff for the engine, and all poly bushings both front and rear.
polished the rear wheels this weekend though ;)
Share this post
Link to post
Share on other sites
Put my new camshaft in. It has a higher lift and really makes the engine come to live after 5500rpm were it lost all it´s flow before.
its a turbo camshaft from ipdusa.
here you can see the difference on the new and old cam
also put in a new distributor and cap and some new spark plug wires
Did a little buffing on the roof, hood an wing. Thinking about keeping it this way until next winter. just buff the rest of the car, what do you think ?
Share this post
Link to post
Did some more last weekend :)
Put in the original front swaybar, with super pro poly bushings
And also did the rest of the poly bushings front and back
Whipped out the diff and put a spacer in the lsd locker.
ordered 7cm wide plastic fenders and 4x114.3 to 6x139.7 adapters for the front wheels
bushing porn for you weirdos who are into that..
Edited by GretarK
Share this post
Link to post
mostly been driving this thing for the past weeks.
Except a head gasket change, new clutch with a heavier pressure plate. Putting in the heater element. New rear wheel bearings.
Making a oil catch can, and some other smaller stuff :P
here are a few pics of it in action
Edited by GretarK
Share this post
Link to post
Lovely ride mate :)
Just a quick question if you wouldnt mind;
What coilovers are you using?
edit: and how tall are the tubes you made for the coilover mounts in the rear?
Currently building a 1980' ke70 myself :) though with a sr20, and a volvo rear axle :)
Edited by ander89
Share this post
Link to post
Lovely ride mate :)
I'm using s13 200sx coilovers because the front struts are from a 200sx ;)
I can measure the tubes but it wouldnt help much unless you are using the same setup. And I also made the brackets on the rear axle.
The way I did this, I put the coilovers in the highest position and bolted them on to the axle and mocked the rear axle under the car with wheels with room to lower it. And measured from there how long the tubes should be.
Share this post
Link to post
as for updates, broke the volvo transmission. So I'm fabricating a 6 speed BMW ZF transmission on the back of the volvo engine. with a 6 puck copper clutch and heavy duty sachs pressure plate.
Got a fairly unused Turbo from a Evo X and will be fabricating that in there also.
and probably a rollcage for the season.
But this thing has been stealing time from the KE70 past few months :)
2tc with t50 and twin webers 9 and 11" wheels. pretty fun making this one
Edited by GretarK
Share this post
Link to post
Sweet, thanks for the reply :)
rad looking 2tc aswell :D
Share this post
Link to post
Well, I planned to do a little makeover on the rolla last winter because the body was really getting rusty and I really don't want to see it go any further with rust damage.
Also built a full roll cage in this process.
And by a complete accident put my volvo engine up for sale and sold it the same night.
The plan was to buy a 1jz and squeeze it in there but, went with a 2jz instead.
A borg Warner s360, 1000cc bosch injectors. And a 6 speed bmw gearbox conversion.
So an accidental complete rebuild of the car was suddenly in progress.
Here are a couple of pic that show the process
the shifter assembly that I made for the bmw gearbox.
and a sneek peak at the color
the 2jz to bmw adapter kit I'm using.
and a couple shots of the angle, still got a bit of travel left in my steering rack. But have to make new control arms to make room for it.
Share this post
Link to post
