All Activity
- Last week
Banjo started following Most reliable rollacar and Photo Too Big!
Hi Jack, Welcome aboard ! Plenty of ways to reduce the size of the picture file. How to Reduce the Memory Size of a computer image (.jpg) Easiest way, is in MicroSoft "Paint". Cheers Banjo
Use online image compressor tool.
drinky1992 joined the community
She looks a bit lower than standard maybe that has something to do with filling the wheel arches
Do update your thread when you have an answer. I'm sure the info will be relevant to other application also.
Thanks for the reply Parrot. Ok, advice taken. Will talk to my engineer about what I can do. Cheers
Oleg joined the community
Hey everyone, Found this picture of Corolla KE20 coupe, and I really like how it is done. Any chance someone can estimate what wheel and tire size it is? I assume these are SSR but is ti 14x7 or 15? I wanted to go with 13" but they do not fill the arch properly in my opinion. More photos available here: Old Japanese Cars Toyota Corolla KE20 📸 @deanmacarello #oldjapanesecars Facebook
5gotie joined the community
It’s more complicated than that, and the attraction of the Starlet rack is its narrowness with resultant reduced impact on steering geometry, which can be a problem with wider donor racks. A basic understanding of recirc/worm steering will tell you that retaining the standard steering column isn’t an option if you go rack and pinion. These days you may want to look into electric steering and so forth. Still requires mechanical attachment to the wheels however. As ever, worth a chat to an engineer sooner rather than later once you understand the issues, and source of necessary parts
Some early 2000s FWD Corolla by now. They decrease in value for 20years, then the remaining ones go back up. Look on Gumtree, not Carsales.com... $2000 should get you one. https://www.gumtree.com.au/web/listing/cars-vans-utes/1334628803 RWD?? Well, KE70s goes for $10k and upwards... None on Gumtree today, and never on Carsales. Best RWD buy would be Coronas. still immaculate ones around town driven by old farts..
Well that would be a pretty easy answer, when You've reached this site ! However, let's ask the experts that Google AI finds; & surprise, surprise ! https://www.madmanmotors.com.au/blog/top-10-most-reliable-used-cars-in-australia/ Three of the top four reliable vehicles in Australia, all come from the Toyota stable ! Four of the top ten vehicles; are also Toyota. 1. Toyota Corolla 2. Toyota Prado 3. Ford Territory 4. Toyota Camry 5. VW Golf 6. Toyota Hilux 7. Mazda 3 8.Subaru Forrester 9. Hyundai i30 10. Mazda 6 No further correspondence, or opinions will be accepted, thank you ! The experts have spoken. Cheers Banjo
nameas started following Most reliable rollacar
What would be the most reliable and cheapest rolla car available?
nameas joined the community
Darrensan started following KE10 Steering upgrade
Hi, I understand that the KP61 Starlet rack etc is a popular choice for upgrading the steering in a KE10. Would the steering rack from a KE70/AE71 be a possible fit? with some mods? Or are there any other racks that may be a possibility? I plan to keep the factory column but upgrade to a rack. Are there any problems with this way of thinking? Any advice helps. Cheers
Banjo started following Upgrading Ke70 Headlights and Ke70 Radiator Measurements
Hi Haydn, Another alternative; is to use a aluminium cored radiator, from a later model car, that already has an integral electric fan built in. The aluminium cores are more efficient in transferring heat; & an integral fan, is usually a better option, than adding a fan to an existing to a radiator; particularly if it's one that requires "zip-ties", through the core itself. If you scroll down through the following thread, there are some photos of my "Toyota Echo" radiator mod, to my KE-30 Rolla. https://www.rollaclub.com/board/topic/85079-aftermarket-aluminium-radiator-coreshroudfan/#comment-736509 I did it a few years back; & it's one of the better changes I've made. It is so efficient, at removing heat; that the fan rarely comes on. I hooked a pilot light up, on my dash; which shows when the fan is thermostatically switched on; so that's how I know. Cheers Banjo
Anything you can find at a wrecker, or the Australian company that makes fans, Davies Craig. I used a Mazda 121 fan I ran the wiring into the original relay box by the battery and used an empty relay spot. Its controlled both manually and by a temperature switch. That's all in The Girls KE70 story somewhere.
Errow joined the community
whats size for electric fan can fit to standard radiator ke70 DX 4K engine?
Banjo replied to Thomas Dillon's topic in General Discussion
Hi Thomas, I've used both solutions on one of my test bed engines. The one on the aluminium spout switches the electric fan, & the one Altezzaclub suggested; I use to log the coolant temperature on an independant temperature data logger, so I can see exactly what the cooling system is doing. Cheers Banjo -
altezzaclub replied to Thomas Dillon's topic in General Discussion
No, if you drill the larger diameter one you will find its only a few mm thick, nowhere near enough to carry a thread. Clean them both up with a wire brush and dig out all the corrosion holes and see how bad each one is. It wouldn't be the first time I've filled the craters with body filler and had them last for years. The bigger one is the ideal one obviously, but any temp fitting will have to go in the head, where the alloy is thicker. The best idea would be to buy an in-hose fitting, I've used them for years. https://www.ebay.com.au/itm/225253674996?chn=ps&_ul=AU&_trkparms=ispr%3D1&amdata=enc%3A1Im-dDrB5R7C86KkC0s-uAw42&norover=1&mkevt=1&mkrid=705-139619-5960-0&mkcid=2&mkscid=101&itemid=225253674996&targetid=2367800370202&device=c&mktype=pla&googleloc=1000339&poi=&campaignid=21776442415&mkgroupid=173963205248&rlsatarget=pla-2367800370202&abcId=10047386&merchantid=7667992&gad_source=5&gad_campaignid=21776442415&gclid=EAIaIQobChMIsPrt9KeWjgMV9yutBh11xhHNEAQYASABEgLGPPD_BwE -
Hi Thomas, Yep, the one with the larger outlet, would seem to be the way to go. However, if it was me, in your shoes; I'd give both top outlet sockets a really good rub back with a rotary wire brish, on a drill, & then take a look to ensure there isn't any unseen corosion, that may compromise your project. A brand new 80 grit emery paper unside down, on a hard flat suface, show clean those gasket flange surfaces up sufficently ? Cheers Banjo - Earlier
Thomas Dillon replied to Thomas Dillon's topic in General Discussion
Hey fellas, tezza - to be honest mate that’s probably a little out of my wheelhouse at the moment. This motor I presume will be pulled late next year for an overhaul at a local legends (Charlie b) workshop so I’ll leave that one for him. The thermostat housings have arrived and we’ve got two options. You should be able to make sense on what I’m talking about from photos attached. Option 1: has a temp switch hole tapped in already, but the outlet diam is small than our other option… option 2: tap a hole into the housing with a larger outlet. This outlet will match the rad inlet what do we think about this? I don’t think it’ll make a such difference but in a perfect world I'm thinking tap the bigger outlet cheers fellas, input much appreciated as always -
Good morning all ! I noticed this thread was started way back in 2010; 15 years ago ! A lot has happened in that interrim period. Thank Heavens; as back then, there were limited ways of improving headlight performance; both in terms of brightness & lower power consumption. I would therefore offer this link, as a pretty good place, to learn about all that is available out there now; & being an aussie site, also has some comments about ADR requirements. https://www.stedi.com.au/blog/post/complete-led-headlight-conversion-guide#overview It's one of those subjects where there are several parameters, that affect the ultimate goal, of being able to see; further/clearer/brighter, than what our Rollas, produced in the 60s, 70s, & 80s; could ever achieve. However, if It is hard to justify the outlay, of several hundred dollars to discard lenses, reflectors, & bulbs; then there are some simple mods You can do, some of which Altezzaclub has mentioned above. The single biggest problem with early headlights; was that they were power hungry, & pulled substantial current. Some of that power was wasted as "heat", but the simple ohms law was applicable for a 36 or 40 Watt headlight bulb. Ohms law where (Current = I, Voltage = E, R = Resistance, & P = Power) says Power = Voltage x Current Therefore a dear olde 55 Watt H4 bulb with 12 volts placed across it had P/E = I; 55W/12V = 4.58 amperes current, flowing through it. We tended to always refer to the 55W rating of the bulb as being it's light output. However, the tungsten bulb was not perfect. Anyone who has tried to remove one from a headlight, after it has been on, realises it is hot. That heat is waste heat, from the tungsten filament, that never gets transformed into light. There are lots of places in the headlight circuits, that produce "voltage drops", as Altezzaclub has highlighted. Switches; relay contacts; bad connections & undersized wiring; all act like little resistors in the circuit, reducing the actual voltage that ultimately is across the bulb; & ultimately; the amount of light, that the bulb can produce. All electric power to the headlights, leaves the +ve terminal of the battery, as current, & after it has done it job; returns to the battery's -ve terminal. If You care to sit down & study this path in those horrible Toyota wiring diagrams, it is probably several metres circuit distance. The fitment of relays, directly behind the headlights, is an excellent way of reducing the heavy current path length, for the headlights, from +ve to -ve battery terminals. 30 ampere 12V automotive relays are cheap, & this mod is fairly simple, to implement. The wires that connected to the headlights originally, now operature the relays; & the relay N.O. contacts, are fed 12V directly from the battery & back, via a suitable seperate heavy 20A fuse. There are posts elsewhere on RollClub, where I have described this previously. Every light on my Corolla, is now fed power directly from the battery; & all lights are switched by relays, close to the lights. This I did, prior to LED replacement bulbs being commonly available for every size bulb on the olde Corollas. The only one You can get caught out on, is the turn indicator lights, but I believe there are now plug-in flasher units, that cater for LED bulbs. Cheers Banjo
staminupcanada joined the community
Poorman86 joined the community
That's right. You don't get a high beam blue light with the system like that, unless they've improved it, but I remember I had the blue light working if I put a bulb in the other headlight plug and let it hang there. The original wiring diagram had a resistor in that line to make the blue light work. These days I have a separate little LED on the dash that I wired into the circuit and it comes on with high beam.
Oh I see what you mean so the black male pin plug goes into one of the stock harness headlight plugs the other one unused, then the yellow pin plugs go direct into the headlight bulb and the black wire connected to yellow plugs is ground and the red wire is battery positive.
$30 bucks can not go wrong I will try it out thankyou
That link is now here I think, the change from KE70.com to Rollaclub caused it- Try one of these kits, cheap enough and easy to do for what you gain, its what I now have on mine. https://www.ebay.com.au/itm/144043979533?chn=ps&_ul=AU&_trkparms=ispr%3D1&amdata=enc%3A1vZn3r5k9SwOXM01GB5d-7Q4&norover=1&mkevt=1&mkrid=705-139619-5960-0&mkcid=2&mkscid=101&itemid=144043979533&targetid=2370046502538&device=c&mktype=pla&googleloc=9071791&poi=&campaignid=21766134162&mkgroupid=175112620264&rlsatarget=pla-2370046502538&abcId=10047381&merchantid=115487535&gad_source=5&gad_campaignid=21766134162&gclid=EAIaIQobChMIsafEhaOHjgMVgx-tBh2EejSgEAQYBCABEgIiHfD_BwE The relays pick up off one headlight plug, that's the black male-pin plug in the image, that goes into a one stock headlight plug.
Hello I just changed my headlights over from sealed unit to semi sealed, and upon reading this I am guessing you use a relay to to help with brightness and I am wanting to install relays but the link is no longer working, does anyone have a writeup on how to install relays for the headlights.
That oil pump has seen some rubbish go through it! You should have a flat sheet of half inch thick steel in the workshop, maybe the size of an A5 sheet of paper. You wrap a sheet of 180grit wet 'n dry sandpaper on it, spray some CRC on it and wipe that oil pump base around and around until the grooves mostly vanish. If you're keen, take the pump off you can do the bottom of it and do the impeller too. Then clean them all really well! Anything that needs to be flat can be sanded, like a thermostat housing that has had the aluminium pulled out of shape by some guy with big spanners. There will be a gap listed in the 4K manual for the oil pump rotor tip clearance. A thou or two I expect.
