August 4, 200422 yr comment_15854 What can I do to make my 4k engine more powerfull? I want about 100hp +/- Report
August 4, 200422 yr comment_15859 do some research, we've gone over this 10 billion times http://www.superjamie.net/ke25/ is my engine basically you need cam, headwork, better carburettor Report
August 5, 200422 yr comment_15871 sports exhaust system Oh how I love that description. It's so... descriptive! Report
August 5, 200422 yr comment_15873 ok, i'll elaborate. for the power level the original poster was talking, i would keep the exhaust system under 2 inches for a 4k. any bigger and you will just lose low end torque. i would recommend a 1 7/8" system for best all round performance for a high output street engine. find a place that does good work, one that will let you watch. i don't think mandrel bends are really necessary (only a 4k), so long as they use thick wall tubing and know how to use a press bender properly. get them to put a 3 bolt flange on the extractors, you will be a lot happier when it comes to an engine change. Report
August 12, 200422 yr comment_16581 just do what i did, bolt on the first turbo you see, use a blow thru carb, wind up the boost, and have a spare motor at home! :D or you could do it propelry if you want it to be reliable :dry: Report
August 12, 200422 yr comment_16583 exactly. when it went bang, i just dropped in another not hard at all Report
