Leaderboard
Popular Content
Showing content with the highest reputation on 05/12/17 in all areas
  1. Max, l've been thinking about this. Probably one or more of three things. ! 1. Running whilst very retarded. 2. Running very lean, which often causes it to race. 3. Has a big vaccum leak on the inlet manifold or under the carby. Cheers Banjo.
  2. Sounds like a cooked engine tbh. I'd love to have a look also!
  3. Hey Max, Just leave it now until tomorrow & it cools down ! Dave said you can't break a 4K, but you've got a serious problem there. if I was in Sydney, rather than Brissy, I'd be round there in a flash. Love to know what's causing this issue. While the engine is running & this exhaust manifold is glowing red hot, does the engine make any unusual noises ? I think it's back to the drawing board. Forget about carby & dizzy tune & settings. Time to pull all the spark plugs out, do a compression test, and maybe a leak down test, with compressed air. My guess is that big bang you experienced has blown something. I think there is something basically wrong with the engine, and you need to check out the engine integrity first before anything else. Cheers Banjo
  4. 1 point
    With your 5k budget, I'd suggest making it handle and stop better before any engine mods. Coilover set up - depends how full out you want to go. but a full set up is around the $2k-$2.5k mark rear reset leafs - depends where you go and how you do it but around $300-$500 sway bars - anywhere from $10-$300 front brakes - new lines, calipers, pads and everything you need. around $600 New bush kit - $300 rear brakes - best way is shortening a different diff. but that can cost alot. Probs other stuff that i have forgotten but you get the idea
  5. 1 point
    Hi Joey, Welcome aboard ! OK. Others on here will need a few more details, before providing suggestions on what you could/couldn't ; should/shouldn't do. I presume it has a manual gearbox ? Is it a 4 or 5 speed ? Is the "adjustable front suspension" referring to coil-overs on the original struts ? Has anything been done already to upgrade the brakes ? How much have you budgeted to spent on your little beauty ? (Just love those KE35s) Had a KE55 coupe for years, but it went to "cancer heaven". As a very minimum, with minimal mods & costs, I'd suggest looking at replacing the 3K with a 4K, unless you are competing in club classes for 1200cc & under. It always comes down to how far you want to go, & how much $$$ you can afford to spend. Another big consideration, is how much of the intended "conversion" work you can do yourself, & how much you will have to pay others to complete. What other vehicles do you have in your "bunch of cars" ? Cheers Banjo
  6. It's always refreshing to hear someone having a decent run in with the po-po.
  7. Hi Tim, Welcome aboard !. KE series cars were built before baby cars seats were a commodity, so I'm not sure they were ever originally designed to accept car seat mounting & loading points. When I've had the back seat out & the parcel shelf removed to reline it, I noted the "iron work" in that area supporting the parcel shelf didn't look thick enough to be used as archorage points for the back/top of a baby seat. The existing rear seat belt anchor points are from the floor under the seat, & above the rear wheel wells, To ensure you are legal, I would suggest going to a company that professionally fits baby car seats & modules. I'm sure they would have come across this issue & know a solution, or could advise you. Maybe there is someone on here who has been through your exercise previously, & can shed some light on a solution. Let us know how you go, & good luck ! Cheers Banjo
  8. Hey Banjo Just a query my repair manual says 0.45mm for the points gap and 0.8 mm for the plug gap. Have I been setting it wrong on the Princess' rolla?
