Leaderboard
Popular Content
Showing content with the highest reputation on 08/07/18 in all areas
  1. 1 point
    I put one a vdo one on a 4k. I don't recall having any issues. The threads are all standard sizes. Worst case you'll just have to get a threaded reducing bush. M12 to m10 or something. I only said vdo cause they are a known brand and are dirty cheap. And the gauges look fairly OEM. On my old ke70 I put the vdo temp gauge inside the cluster where the old temp gauge was. Just hacked it up and stuck it in. Looked factory. Any gauge with numbers is the go. Like banjo suggests even a $10 jobby will do! I'm a sucker for data so I always put a proper temp gauge in my old cars. Gives me something to stare at in stop start traffic.
  2. 1 point
    "The best way is to install a proper temp gauge and use a thermometer to check its accuracy. " Yep- buy a 110deg thermometer for $10. Then idle the motor from dead cold to the maximum it gets to with the rad cap off and the thermometer in the top of the radiator. You can slip a sheet of newspaper down in front of the rad to help it as the motor isn't under load. Note down the temp and time it takes, and you will get a curve. If the temp gets to 100deg you have a problem, the cooling system just isn't up to it anymore. It should show cold, then quite quickly go to 75deg or so, and slowly climb to maybe 80 odd. Then you will know what temperature the marks on the gauge really mean. In pouring rain it shouldn't get hot at all.
