88 -
Real Name
Zak
nz_83_dx's Achievements
2
Looking good. Not long and you will be on the road again.
Make sure you buy one of reasonable quality, it’s not particularly nice having the steering wheel come off the boss kit whilst going around a corner (I’m talking from experience here).
Would be very borderline. You will most likely will need a slight roll of guards, especially the rear.
Will An Ae86 Radiator Fit Into An Ae71?
nz_83_dx replied to slipn's topic in AExx Corolla Discussion
The ae86 radiator will not fit directly into a ae71 without modifications to the radiator mounting points, there are other easier options if your looking for a upgrade. -
Is your TPS calibrated correctly? I had the same problem with the idle on my 4age.
To Do A 5K, 7K, 3Sge, 4 Age Or 2Tg Conversion???
nz_83_dx replied to MattJA's topic in Engine Conversions
I think a 1GZ-FE would be very appropriate. -
Just clean it up and use some vinyl spray. It pays to go for the higher quality (more expensive) brands as they provide a much better finish. Vht vinyl paint link
Just keep the car above 140kph then, simple.
From memory joint red wires are for reverse lights
Whatever you do, make sure you get a good quality one. The cheap Chinese ones have crap threads- Its not very nice when the steering wheel comes off when your going around a corner- I'm talking from experience here :glare:
does this look right.... So if I'm correct, that means that the rim will stick out 7.89cm from the hub?
Trying to find rims that ovoid rolling and flaring if I can Ill have a measure up tonight and see what i can fit, Cheers for the help
Ok, the deal fell through on the 14's. Now looking at 15's Will 15x6.5 +5 offset on the front, and 15x7 +10 offset on the back fit without hitting anything or for the need to flair guards? Thank you for your help!
Hi, I am looking at buying some ssr longchamps for my ke70. They are listed as 14 inches +6 offset 6.5inch wide, with 175/60R14 tires. Will these fit without flaring guards or rubbing? And yes i have searched and am lead to believe they will fit, but just wish to confirm before I spend large sums of money for them. Thanks.
To me it looks like the one that connects to the oil pressure sensor. Its located on the left of the extractors by the oil filter.
