Everything posted by novaluke
Ke25 Brand New Radiator
Does any one know from were to buy a replacement radiator that fits exactly on ke25? The ones on eBay are all longer from the height and bonnet will not close.
Toyota Tail Lamps
Maybe this helps i found maybe the original packing and it has this code 81551-36120
Toyota Tail Lamps
All ready tough about it but they are a little different they have a piece of chrome between the amber and the break light and amber shape is not in a semi circle like mine.
Toyota Tail Lamps
Found out that the second one is from a corona. Could the first be from a toyota publica/800 or maybe hilux?
Toyota Tail Lamps
Hi can any one help me out. I have bought these tail lamps but do not know from which car they came from. They are Toyota for sure. Thanks.
T50 Gearboxes
Hi may i ask a question. The clutch fork and the clutch release bearing diameter of a t50 are they the same from 20 spline to 22 spline? Thanks
T50 Thrust Bearing
I think i am missing something called "carrier"
T50 Thrust Bearing
Hi guys thanks for the help when searched in toyodiy it gave me the same as the screen shot i sent out before. I can buy them new from toyota but wanted to be sure abut them. A friend sent me a clutch fork and a thrust but did not fit. I guess will have to buy the toyodiy part numbers and hope it will fit.
T50 Thrust Bearing
Hi i had bought the engine form abroad and i don't know form which car it came but it is 20 spline. The prob is that he did not sent the clucth fork and thrust bearing and i need a pair.. The part numbers that i have sent are they any good? If you maybe can give me a link were to buy it or you know the Toyota part numbers it would be helpful to me. Thanks. This is my gearbox
T50 Thrust Bearing
Hi guys i need some help finding the right t50 thrust bearing. I have took a measurement were the bearing is going to be fitted Is it a correct t50 measurement and are these part number good for me? If no can some one at lease give me the original part numbers or some help as i do not know what to do.. Thanks
Badges
Another question, do you know what theses are worth and what is the specific name for them? Body side Chrome? Thanks The left one has a little mark.
Badges
Same mind i put them up on ebay with a reserve. You don't find them that often these badges and i want to go for the levin look either way one badge is no good i need 2 if I'm going to use them.. So better sell them and fund my restoration ;-)
Badges
Thats what I'm going to do but wanted to verify the price before i do them.
Badges
The pins are there on bought
Badges
Oh i see could be. Thanks ;-)
Badges
Ali's Ground Up Ke25 Rebuild
I made it one to so i can repair the rust more easier and to spray it form the underneath. When it will be ready from blast i will upload some photos for you to see it.
What for the rotisserie? It was done by me it and not expensive.
Corolla Ke25 Project From Malta
A year after ready to go to blast tomorrow. Change of plans for the engine going to a standard 2tg.
Hi at the moment i am doing mine exactly as yours. Basicaly i hand removed with the paint remover the delicate places were the sand blast can damage the body other wise its sand blast. I have found that a metal sponge (used to clean dishes) best for some tight corners. Your just leave the paint remover to set more than 15 min and then just removed with it. I have exactly the same rust probs like you. I have removed the inside membrane with a blow torch and a scraper it was easy now tomorrow its going for blast. In my opinion blast is the best for some tight corner and round edges were its much more stronger so they can be sand blasted with out damaging metal. Mine at the moment
T50 20 Spline Yoke
Hi can any one confirm for me if this is a t50 20 spline design yoke? As yoke can see there are two slots like missing. Thanks
Te27/ Ke25 Break Set Up
No its going to be used for a sunday drive or maybe for a show so i thinks they will be good. What about fitting a ta22 break booster would it be difficult? And has anyone done it?
Hi guys thanks for the reply. I live in Malta and all the items you listed is n/a imma Malta to find so i have to find them thats why i wish to be sure. In Malta there arent that much laws as long the car stops its ok so i can leave it how it is. I just want to improve them for my own saftey and just to look more nicer but like i said all these parts have to be brought from abroad as here in Malta there arent such parts..
Hmm ok. Do you think my curret break set up will be good? Or is there some thing simpler i can do to increase my breaks thanks.
Hi i currently have a 3k in the car with this break set up. I am planning to fit a 2tg engine in the car and was thinking what types of break shall i upgrade to. I have managed to find a te27 break booster but i came from a left hand drive car. My question is to install it is it just a matte of bolting up or do i need to modify the pedal box? Thanks
