Nutta1
    21
Nutta1 last won the day on January 6 2016
Nutta1 had the most liked content!
  • Location
    sunshine coast
Recent Profile Visitors
1523188 profile views
Nutta1's Achievements
  • Conversation Starter Rare
  • Week One Done Rare
  • One Month Later Rare
  • One Year In Rare
Recent Badges
  1. Short and sweet I'm trying to track down an idler arm for a 77 KE30 4DR. I have gone to numerous shops and ebay with no success any help would greatly be appreciated.
  2. SORRY FOR ALL THOSE THAT HAVE READ AND RESPONDED TO THIS QUESTION MANY A TIME BUT CAN THE GOOD PEOPLE HERE GIVE ME AN OPINION ON WHAT SHOCK ABSORBER THEY THINK WOULD SUIT MY KE30. IT HAS BEEN LOWERED 63mm or 2.5in ALL NEW BUSHINGS FRONT AND REAR. SITTING ON 14in TOYOTA RIMS. MAINLY STREET USE. THANKS A MILLION
  3. Happy New Year to all Just a question that probably has been asked many times before. Does the stud hub have to be pressed off when replacing the front disc rotors or are mine just rusted on I have undone the 4 mounting bolts but no luck this is on a 77 KE30. Any help would be much appreciated
  4. I have a 4K motor available suit a rebuild if interested where are you located I'm on the Sunshine Coast QLD
  5. They do exist I have managed to find 2 × 4Ks and 2 × 5Ks + 5 speeds to match
  6. I have a 4K bored 40 thou 10:1 comp 30/65 grind cam not sure duration ported head just curious would twin 40 weber carbs be too much thankful for any advice
  7. Can anyone recommend a good suspension shop on the Sunshine Coast QLD or North of Brisbane to get my leaf springs reset thanks
  8. I did this many years ago the only drama I had was the clutch plate splines were different but I think that may have been a stuff up from the clutch and brake shop just check the number of splines before installing otherwise straight forward swap.
  9. can a 4k motor be bored out 60 tho safely.
  10. Archm Industries in Bayswater Victoria Australia sells lowering blocks 1inch to 3inch for jap and ozzy diffs check on ebay under 1-2-3 inch KE20 lowering blocks. Hope this is helpful
  11. Can any of the ac from a KE70 be converted to a KE30 with a k motor
  12. THANKS TAZ YOUR VERY KNOWLEDGEABLE. THAT SHOULD MEAN IT WILL REV A LITTLE MORE OR WOULDN'T YOU NOTICE IT
  13. just a quick question is the 3K flywheel the same as the 4K
  14. after purchacing a KE30 recently matching number vehicle. needs a little tlc but is rust free and original which has pointed me in the direction of rebuilding the 3k motor i like the idea of injection so the question is does the 7k injection manifold set up fit a 3k motor or am i better off sourcing a 5k motor and going down that avenue. i want to keep it looking as original as possible
  15. Sorry taz didn't understand your thread pictures of turbo carby motor. I'm after injected thank you
