Hey guys, it's Sunday morning, 9:45am and I'm in a spot of bother.
Background:
Best mate ! (wife) blew the head gasket in my KE55 coupe during the week. Thermostat jammed closed (Oh I hate those troublesome things) and she didn't notice the temperature guage climb into red area. (have you ever met a girl that drives & looks at the guages at the same time ) Picked me up from doctors & said the brake are making a funny smell. Lift bonnet. Smoke coming out between head & block. Ohhhh !
Tow car home, lock wife in broom cupboard as punishment, & remove head yesterday.
Strip down & clean & get ready to take off the local engine recond. factory next week for valve faces, grind & head skim etc, (as you do after such an occurence)
Drop one split collet on driveway (gravel) and after two hours on hands and knees looking like a Ben Landin devotee', give up.
Gret Idea !!! I've got a donor 4k engine in back of garage, that came out of my first KE55 coupe, whose shell went to Toyota Heaven, after developing cancer. (I kept it's heart & soul)
Oh. and I remembered I had overhauled head not long before it was taken off road, so should be in good nick.
Off with head, clean up, (with that great $1.99 spray degreaser you get in SuperPro) and on with head last night, new gaskets, torqued everything OK.
This morning, all I have to do is fit rocker gear, adjust tappets & throw the radiator etc back in. Easy ? No !
I decide to use the pushrods that came with the donor head because they are cleaner. Better check they are the same. Oh no. They are about 5mm shorter than the ones in my engine.
Refer to good book but only difference Haynes Manual states with 4K was a slightly different compression ration for 4K fitted to manual & auto model, but no details.
Quick check between my engine reveals the following.
Donor 4K engine number 4K 588 series
My 4K engine number 4K 902 series
Donor 4K engine had dished piston tops with recess for valves (Ohhh!)
My 4k engine has flat top pistons like the picture in manual.
Donor 4K engine has overall thickness of about 76mm.
My 4K engine has head overall thickness of about 81 mm.
Rocker shalf supporting bosses are the same height.
Donor engines pushrods are about 5mm shorter that those from my engine.
My 4k engine is already assembled with donor head, so I adjust tappets and turn it over with small torch down spark plug hole. Flat piston head does not touch the valves during any part of the cycle travel.
All this background is to ask the following questions.
What variations were there in the Toyota 4K engine series.
Can the heads I have described above be swapped.
What the hell does my compression ratio finish up being, and will it degrade performance significatantly.
Have done a quick thread search on 4K head swaps but can find nothing. Lots on putting the 3K head on the 4K engine, but nothing I can find for the situation I find myself in now.
Can anyone help.
PM me if you have some experience with my problem. (no, not about how to get wife out f broom cupboard) and I will be most grateful !!!
