dreamin
Regular Member-
92 -
Everything posted by dreamin
In vic its 4x the weight of ur car. In standard form. I looked into this conversion for my ke30. On the rego label vic roads has them recorded at 1100kg when they're only 900ish. So technically i could've got it engineered but i decided against it as it is a costly conversion.
Sr20 Conversion To Ke55 Plus Rebuild Plus Pimpage
dreamin replied to JDM55's topic in Engine Conversions
Hats off to you mate, a ʞ©$ɟin top effort. I'll definately be reading back through your thread for info when i get back onto my car. Well done dude -
Thats ʞ©$ɟin unreal man, definately need some more pics. What stud pattern, brakes and suspesion are you running?
Sucks about the radiator mate. But a bit of welding will be alot cheaper that fabbin' a new one! Car's lookin beautiful man, keep up the good work. -
Crazy dude, very impressive. -
Hey mate I live in Winchelsea. (20 minutes from Geelong) PM me if your keen. Cheers
lookin good mate, i like those rims
Bit more progress, the front is nearly finished. I pressed up two pieces of 3mm the same profile as the corolla control arm 40mm long and welded them in. Then i just had to re drill a couple of holes to suit the new length. Then fitted the rings to take the commodore ball joints and painted em up. I couldn't get a very good pic of the strut in there because the sun was setting i stuck the wheels on and the camber is spot on, i have a way bigger choice of rim now which will be good. The only thing i need to do now is make longer steering arms up then clean up and paint the struts with lowered springs. Gettin there...
Glad your back into it man, this is an awesome build. Very inspiring -
I like this idea, i was gonna do it a while ago. My plan was basically to cut the back off and weld the tailgate back on behind the pillar and make a tray for it. I didnt really look into it to much though but thought it would have looked pretty stock. +1 for the 1UZ aswell
ya need to take the bov right out before it will does mate, and ya need a fooly sick does pipe
So i've been doin the maths on the front end a bit more and have decided to scrap the idea of machining the ball joints down. I'm gonna use the corolla control arms which i'll have to make them 40mm longer which be easy enough. Then cut the hole that takes the ball joint bigger to take the ring off the commodore control arms for the ball joint and weld it up. Then i'll just have to get kingswood rotors which will bring the wheels back in 10mm and they should be sitting right. Today i cut the mounts off the rolla diff and welded them onto the vn diff so thats all done apart from axles which will be done soon. Tacked up Ran out of gas so i used the stick welder for it
Yeah mate just need a picture etc to go off, just let me know if your interested. Cheers, Mick
Hey guys, i can make them no worries but i'll need some pics or measurements for them. PM me if your intersted Cheers
Ok so i'm still waiting to get on the lathe and machine down the vp ball joints so I bought a vn diff and shortened it this morning. Just have to get the axles shortened and swap the mounts off the rolla diff over. Shortened and welded All buffed up
Been making a bit of progress lately, i got all the panels painted and hung on the car and i also put some blue pearl over the top aswell. I was pretty happy with it being my first paint job. Here are some pics. I will get some better pics in the sunlight. The pearl really shows up in the sun. Still got a few bit missing which i'll get new. Started on the front end suspension and brake upgrade today, i bought a pair of vp commodore struts with v8 brakes measuring 295mm. The only modification i need to is get a set of vp ball joint and machine the bases down to the same diameter as the rolla ones so they'll fit in the rolla contol arms. The strut tops are the same, the steering arms will line up no worries and the brake lines are the same. Big size difference Next i will be shortening a vl disc brake diff and swapping all the bits off the rolla bits over so it bolts in and shortening a tail shaft. So then i'll have the same 5 stud pattern all round, good brake and suspension upgrade. Then motor....
thanks mate i'm really happy with it, it gave me heaps of motivation to finish it then i busted my leg on my motorbike that arvo. GUTTED
So i finally bit the bullet and bought some paint, its the mystic green pearl off the new falcon. This is the first car i've painted so i just took my time and it come out pretty nice! It looks awesome in the sun
Bit of an update after ages of not being motivated, finnished wet rubbing the shell today, just a small rust repair to do on the right wheel arch. I have a question for all the painters out there, my plan with painting the car was to do the door jams and under the boot, then paint the inside of all the panels, re-assemble and then the paint the outside in one hit. any advice on this? cheers
Picked up another rolla last week. 90.000kms, no oil leaks, reco head, new hoses, fairly good bodywork. Stock as, all ihave done is pull all the door moulds of cos it was missing a couple. Got it with rego for 500 bucks, tell me what you thimk and maybe what its worth. Also what i should do with it, i was thinking lower it and put some whitewalls on there. Cheers
thanks man, turbo sounds like a good plan :jamie: its gonna be dangerous
Bit of an update. got a bit done today. etch primed the other 3 doors then hung them all up along with boot and the bonnet and high filled them all. Gettin there slowly. If anyone has any tips or whatever i would appreciate it as i'm not a painter, i'm a welder. cheers guys :D
Whats with the sarcasm? i used the search function and wanted more info. I'm just tryin to learn as much as i can before i pull anything to bits
