Evan G
    3817
    23
Everything posted by Evan G
  1. like really how hard is it to look in your rear view mirror when the garage door is down?
  2. hahahaha ill belive you then sir. i reckon people should get instant fines if both brake lights are out and a warning if one is f@$king pisses me off
  3. it ate the engine? bs? pics?
  4. uhhhhhh "Is it true that if we had have used the fire extinguisher on the battery that the car would have been a write off? because of the contents of the fire extinguisher? " well theres different types of fire extinguishers if they didnt use a blue or electrical extings i can see everything arching out but no being a f@$king write off?
  5. bahahahhahahahah :)
  6. maybe mungi mod power?
  7. but isnt this bad on performance (what evers left)? you want the air colder not heated up by the exhaust manifold?
  8. prob a welded diff?
  9. Evan G
    Oke020
    pic doesnt work :P
  10. sounds about rite LMAO
  11. is the hot box where the top of the exhaust manifold sits in the intake?
  12. i saw a rough ke20 ute? (90% sure it was a ke20) near pasco vale rd just parked in the front lawn, was full of surface rust
  13. sounds like a afm to me
  14. relocate the battery and have the intake in its place?
  15. HEY NICE ke55 in the backround :D
  16. um so you changed your diff now your auto isnt changing gears as it should?
  17. is this the one that sold for $3000 with seized brakes?
  18. update i remove the buggerd stud without causing to much dramas why is the idler arm so close to the exhaust? anyone else had this problem? theres a 1mm gap between the exhaust and the idler arm witch leads me to believe thats what cause the stud to bend. i tried to lower/raise the engine mounts to get more clearance but nothing. engine mounts aren't cracked/sagged. so i cracked the shits and cut a small bit of the top of the idler mount off. now theres a 6mm gap. hers a pic of what was left of the gasket
  19. wgmg - trying to understand if paranormal activities is real or me thinking its funny and a load of shit cause it is real and i don't wanna belive it?
  20. GAYYYYYY!!!!!!
  21. Who Wants A Mustache Ride?
  22. try setting the dwell, got a multimeter? also the points gap needs to be set correctly or the coil wont have enough time to energise therefor giving a weak or no spark, also when you change the point breaker gap your ignition timing also is throw out, so this also has to be reset wheres the car? ill come down and have a look but don't wanna travel far with my dodgy fixed ke55
  23. i believe my car is running like a bag of shit, so i changed the plugs for a new set. is 5.00KΩ to high resistance between ignition leads? thanks for any advice. (i left my workshop manual at work DOH!)
  24. wgmg - when c**ts drive around with no brake lights/ idicator lamps and wanna start a fight when you point at there lights as there turning the corner FFS!!!
