toymotar
    52
Everything posted by toymotar
  1. air ride suspension,ebay seller name "airridehq" got these posted for $75
  2. This is one that may have come out of a 70,I'm unsure,its just a factory toyota linkage cut off,fliped over,and welded to the weber,this is easy and solves the problem of the weber throttle rotating in the opposite direction to standard carb.
  3. Negetive.....i also thought "engine hat" but no,completely different part.. i continue to scratch head
  4. This won't help you at all alec,but i have recently found some left over random bits with a 5k rebuild kit,i agree large one is exhaust but i have a different small rubber bush with washer backing...how interesting...
  5. yes thats fine m8,just call me and let me know 0406195004 adam.cheers
  6. i have one here $20 already out of car,shifter missing few bitstho,but don't think you need that as allready have one.i live in macleod,come and get it next time your in the area :)
  7. are you still after auto for ke55?
  8. Hey mate, As far as i know..(not very far) there is no factory relay on inner guard near battery,maybe old aftermarket spot lights??
  9. unlucky for me...thanks m8 :)
  10. Can anybody tell me if these are factory 5k pistons?.. or are they aftermarket? :)
  11. A few months back i tryed to find new oil pump for 4k(i assume they the same as 5k) rang heaps of places and hours of net surfing with no success,i guess they never failed so nobody stocked them.hope you have better luck.
  12. Thanks heaps guys! ..its nice to know helps not far away :lolcry: I'm sure ill have plenty of other probs in months to come.
  13. that helps heaps,cheers..no vacuum addvance it is then. ;)
  14. This is the carb...may help. ;)
  15. Yeah i would like to,just not sure where or if my dellorto can..?
  16. Thanks rob! ;)
  17. Hi guys, I am currently building a 4k with a single sidedraft dellorto,does anybody know what i should do with the vacuum advance line from dizzy? ...and will it run correctly without it hooked up? any help would be great!
  18. Hey Ben,I found your pics....duh. Man that ke70 is so overrated! it should be in a museum.
  19. Hi everyone,I'm Adam from North Melbourne i drive a 1978 ke35 and have 1971 ke25 back home in kiwiland stored and waiting for my return.I'm always doing somthing on my ke35 and keen to see what other rolla heads are up to!
