November 17, 201016 yr comment_482725 Hey guys, Alec here again. Sorry bout making so many thread, i'll get around to making a rides thread soon and put all my queries in there :happy: Anyways, i've just rebuilt my first 4k for my 1983 Flat front KE70. However i've got three pieces left i have NO idea about. I'm only new to this so be gentle. Pretty much i have a rubber O-ring that looks like a possible dissy seal or somthing, and two strange round rings. I have absolutely no idea what they are for. Can someone please help? Cheers Alec Report
November 17, 201016 yr comment_482726 those silver rings look like "gaskets" for exhausts. like joining 2 peices of exhaust together with flanges. are they sorta ceramic? no idea on the rubber thing. Report
November 17, 201016 yr Author comment_482728 yeah that could make sense dave, its strange tho that the outer diameter of both the weird "gasket" things is the same, but the inside diameter is different. i tried taking that second pic up close but my camera is shit. yeah, its like a ceramic sort of material inbetween the layers of metal strip, its quite odd. Report
November 17, 201016 yr comment_482729 yep they sound like exhaust gaskets to me. i can't recall the form of the ke70 exhaust but i did replace one in my old stocko ke70 exhaust. half way down the car somewhere there is a join. i did howeever have to replace them in my stocko 4age exhaust manifold, where the 4-2 part joins the secondaries there is one of those ring things on each runner. they are a fairly gineric item, and the internal diameter doesnt matter to much, so long as the external diameter fits where its supposed to go. the rest is just crushed and seals it up. Report
November 17, 201016 yr comment_482730 What are the Internal and External dimensions of them, the one on the left looks like a seal for the crank shaft or maybe a gearbox seal. And like dave said the other two look like exhaust gaskets but if the diameter is too big then it's a dw part. Report
November 17, 201016 yr comment_482752 The rubber one looks like it is the seal inside the oil filler cap screw on type . Report
November 17, 201016 yr comment_482760 If you can't figure it out you can always spend a few hours looking at toyodiy pages for the parts you have on your desk :P http://www.toyodiy.com/parts/g_G_1983_TOYOTA_COROLLA_KE70R-EEMDCQ_1.html Report
November 17, 201016 yr comment_482768 17401B - gasket exhaust pipe (before intermediate pipe thingo) 17451 - Gasket exhaust pipe (after intermediate pipe thingo) 11302A - gasket for timing cover (my guess) .............................cause I'm bored Report
November 17, 201016 yr comment_482893 This won't help you at all alec,but i have recently found some left over random bits with a 5k rebuild kit,i agree large one is exhaust but i have a different small rubber bush with washer backing...how interesting... Report
November 17, 201016 yr Author comment_482894 oh alright, cool so the two weird ones are exhaust gaskets, i don't thnk the rubber one is anything to do with the timing cover. i hope not haha cheers for the help guys ps oh Toymotar, is that one of the things that slips over the threded rod that goes through the top of the tappet cover (or engine hat) and then the nut tightens over it to keep it down? Report
November 18, 201016 yr comment_482941 ps oh Toymotar, is that one of the things that slips over the threded rod that goes through the top of the tappet cover (or engine hat) and then the nut tightens over it to keep it down? Correct..... engine hat :lolcry: The rubber one isn't a front main seal (timing cover). Not too sure what it might be. Is the other side the same? Just a solid rubber ring? Report
November 18, 201016 yr comment_482961 Rubber ring could be for spark plug o rings, if it was round the rubber o ring I would say dissy ? but it isnt so I'm guessing spark plug tube as there sqaure sided o ring. As the gaskit kit would cover most K variants you will get some stuff left over, Those ceramic things I got heaps in the shed, Cheers Andy Report
November 18, 201016 yr comment_482963 Rubber ring could be for spark plug o rings, if it was round the rubber o ring I would say dissy ? but it isnt so I'm guessing spark plug tube as there sqaure sided o ring. As the gaskit kit would cover most K variants you will get some stuff left over, Those ceramic things I got heaps in the shed, Cheers Andy Good suggestion. How many are there? Just one or 4x? Report
November 18, 201016 yr Author comment_482968 TazRx: yeah engine hat always gets me, can't remember what member that was tho. And yeah its just a solid rubber ring, flat on one side rounded on the other. Andy: Nah its not a sparkplug seal, all 4 of them went into my engine. The inner diameter of it is 37mm and the outer diameter is 49mm. I full have no idea. There's only one of them too Report
November 18, 201016 yr comment_483061 The measurements confirm it. As I said above it is the seal that goes into the oil filler cap screw on type . Report
