Ke20 Differences
jamesrolla
is anyone elses car the same as mine, my 1972 ke20 had the id plate on upside down and so does my 1971 car but the 1974 one and the 1973 cars have them up the right way, is anybody elses car the same???
also my 1971 car has drums on the front but unlike the ke10 drums these are twin leading shoe ones so they have two wheel cylinders instead of just one
also does anyone have a borg warner diff in their ke20???
my 1971 car has little pull down handles under the dash to open the airvents on the dash,
it also has one of those grills with the small squares and the lines on the fuel door go across instead of up and down
Edited by jamesrolla
Link to comment
Share on other sites
There are 2 types of ke20's, there's an early model 71-72 and a late model 72-74. Just like there are ke10's and ke11's.
The early ke20's have small tailights different bootlid, front grill and bonnet and are fitted with drums all round and borg warner diffs. The later ke20's are the first corolla to be fitted with front discs and they all seem to have banjo diffs. They also have the longer tailights, plastic grills and the front indicators are on the side of the guards instead of being in the little plastic corner pieces. :y:
Link to comment
Interesting.
So why would have they stuck the ID plates on upside down??
Was the person applying them stoned, drunk or just dislexic??
Its so you can stick your head over the guard and look at it close up rather than look at it from several feet away if it were right way up.
Link to comment
  • 3 months later...
The early ke20's have small tailights different bootlid, front grill and bonnet and are fitted with drums all round and borg warner diffs. The later ke20's are the first corolla to be fitted with front discs and they all seem to have banjo diffs. They also have the longer tailights, plastic grills and the front indicators are on the side of the guards instead of being in the little plastic corner pieces. :jamie:
Hi guys, i have a 5/71 20 SL & 4/72 20 SE. Both are early & both have discs on front :wub:
Link to comment
