Paintin A Ke55 Helpp
heyy
anyone no any good paint places that could do a little panel work and paint a ke55
even if any members do backyarders
something simple but sweet
i have a low budget so under 1000 would be awesome thanks
i no, I'm broke but still :)
Add ya location to ya profile so you don't have to worry about adding it to your posts ?
preparation = 99% of the work
painting is the easy part!
you could bog up, smooth and paint a rolla for around $1000 if you worked along with someone.
the unfortunate effect of new paint is that it highlights any bad body areas, so that small unnoticeable dent
now looks like the grand canyon.
interesting...interesting
does anybody no a good diy site or walkthrough on how to prepare and what you need and paint it and everything?
thanks
in melb
to be honest with you panel beating / body repairs are a fine art. most panel shops will try to replace panels or weld new ones in before trying to straighten panels fully, ie file finish them with no filler.
else its the common straighten it as much as you can and use filler to finish.
thats why a overrated car is worth a lot more than an average one. people complain as to why a overrated car is twice the price of an average one, not realising that to fix an average car to the same condition is about 4 times the price or more lol..
it comes down to either how much you want to spend or what finish you want.
and also theres many combinations of methods and materials for painting which different people use for their way of painting a car to their liking, many which achieve the same outcome.
preparing a car can be anything from a super rusted dented ground up rebuild to a super straight rust free respray wipe over job...
the paint job can be anything from a external shell spray to a complete engine bay / underbody / internal sprayjob.
some aspects:
what is the car like
what type of paintjob do you want
how much do you want to spend - $1000
what skills do you have
what equipment do you have
what facilities do you have
you need to give a load more information, a good idea is to buy a book on painting a car which includes all the nesassary information for you to make an informed decision on what you want, then it will be easier to give you
technical information and advice.
good books avaliable from automotive bookstores in your state, online, friends or maybe the library.
Edited by styler
ahh thanks mate thats really helpfull
well i just want the shell painted
i have about 1 grand to spend
not nuthing spiffy just average
ive tried boggin up the cutout rust spots
i don't have much tools at my house
I'm a first year mechanic apprentice
and just a simple white paint ( easiest colour)
thanksmate your reallly helpful
Just to clarify, there is no such thing as "file finish with no filler". If possible panel are replaced, even then unless your car is post 90s even the new panels are not straight enough for a good job. In ALL cases the panels are staightened as best as humanly possible sometimes using heat to shrink and stretch metal. Filler is then applied and sanded to attempted perfection. The next phase is 'spray bog', this is a filler sprayed over the whole car and when rubbed correctly fixes any remaining imperfections that the hand applied filler missed. To rub this off normally takes 1-2 weeks. This is how show cars are done. If anyone with an older show type car tells you there is no filler in it, laugh at them, because even from factory the panels are not straight enough for a show finish.
no you can file finish, i do it all the time but only on small dints, no fun on dents
the extra time it takes is still half as long as it takes for bog to dry, if you do it right you don't even need highfill primer
(i learnt of this grumpy old italian fellow, he was a master, but a little..... angry, i learnt fast)
The hell you can't.......
I watched a master do this without bondo or any kind of primer/filler short of an epoxy sealer
I watched him pound a dent in an old fender, then try to teach me how to shrink and form it back to its original shape barely filing any metal at all.
Pissed him off when I told him his "art" was a total waste of time in the 'real' world
so the conclusion is?
Grab the Yellowpages and look up some panel shops in your local area. Drop in or give them a call. They are the best ones to speak to as no Melbournians have suggested any places that definately do cheap resprays.
Edited by kangaroosa
