Rwd Auto 4age
I have just brought my first ae71. I just did a search, i was gunna ask about putting a twin cam head on the 4ac, but heard it was a waste of time. mine is an auto and that was why i was trying to find out so i did'nt have to piss fart around with flywheels. Having said that, has anyone bolted a 4age up to the standard auto?. What is involved?
u don't have to change your crossmember as the 4age will bolt to the ae71. you will have to get a 8 bolt flexplate(flywheel) get one off a 4age bigport auto and your ae71 converter bolts to this, then its pretty easy after all that
Its not hard to convert to manual, Can be done in 1 day.
Doin it auto for something different. i'll put a 4agte in it later down the track. Thanks for the info.
Edited by decoop
ill let u no how mine goes ;)
something different? thats weird just go manual
thay are trimatics if you get the right stall it mite take a few shots it shouldn't be a slug
Wasnt the trimatic behind the K motor and not the 4a ?
well i pulled my one out of a ae71 4a and the tag says borg warner on it which is a trimatic
Thats why i'm doin an auto coz everyone goes manual. so if there a trimatic they will have no probs handling the power of a 4agte. or i might save my money and just put a 1uzfe in it :jamie:
i.m a big fan of the sleeper look so it will be sly no matter what i put in it.
depends how much power u have i got 200 atw i don't think that will hold
If they are a trimatic (I'm still not sure...) then std they will fall appart if you throw turbo grunt at them! If they are basically the same box as the Holden ones then the can be modded to handle alot of grunt.
They run trimatics behind vl turbo engines, they just have to be made "bulletproof" as such. If your running a stocker it wouldnt be such an issue.
Remember, they call them a traumatic for a reason... otherwise goodluck!
arent autos 3 speed thats so random....
