  • Replies 140
i have one question on the cooler setup, would it be able to pass engineers? with so much being cut out and all.
Yeah it will. I has been restrengthened with the surrounding of the cut out section tied into the top and bottom.
Besides marty and mick have theres the same way and john from consolmotive has engineered them no problemos
awesome as :) defiantly love the cooler setup then, my cousin's gonna hate me when i take to the freshly undercoated front with the grinder on mine. lol.
so more focus on drags rather then circuit this time around? still staying manual?
  • 4 weeks later...
Yeah hasnt been mentioned.
A mate is building a ke20 and figured he could use a larger tunnel and fit it in the ke20.
This will be full steam ahead when i get back from OS. Around late march.
Edited by cuzzo
Ahk, didn't think you modified the tunnel in it.
  • 3 months later...
Some more updates.
My 2 door is coming along albiet slowly....
This is the rear quarter. It had been replaced before and not in the factory location so the join was a bit dodgey. Especially when i tried to file it flat down and then it cracked. So i had to reweld it up, shape it with the oxy and then fill it.
Also there was a section near the door with a vertical crease. I tried panel beating it out but then it stretched the metal. So out came the oxy again and i shaped it flat again and then a small amount of filler to get it smooth.
Theres alot of other panel beating required. So working through that. I need to do something about this wheel arch also. Should i just add flares or strip that bog and weld in whole new section. Its not perfected round and i need to get it to match the other side. Height and roundness to match.
Suggestions?
The old girl. Off to scrap heaven.
Some more updates.
I would be looking for another rear quarter.
